Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ FAQs/ Node/ Node Running/ How Do I Rectify Failures When the NVIDIA Driver Is Used to Start Containers on GPU Nodes?
Updated on 2025-07-07 GMT+08:00
Did a Resource Scheduling Failure Event Occur on a Cluster Node?
Symptom
A node is running properly and has GPU resources. However, the following error information is displayed:
0/9 nodes are available: 9 insufficient nvida.com/gpu
Analysis
  1. Check whether the node is attached with NVIDIA label.
  2. Check whether the NVIDIA driver is running properly.
    Log in to the node where the add-on is running and view the driver installation log in the following path:
    /opt/cloud/cce/nvidia/nvidia_installer.log
    View standard output logs of the NVIDIA container.
    Filter the container ID by running the following command:
    docker ps –a | grep nvidia
    View logs by running the following command:
    docker logs Container ID
What Should I Do If the NVIDIA Version Reported by a Service and the CUDA Version Do Not Match?
Run the following command to check the CUDA version in the container:
cat /usr/local/cuda/version.txt
Check whether the CUDA version supported by the NVIDIA driver version of the node where the container is located contains the CUDA version of the container.
