Specifications
Dedicated Gateway Specifications
The following table lists the specifications of dedicated gateways.
Edition |
Maximum Number of Requests per Second |
Bandwidth |
Private Network Connections per Second |
Basic |
2000 |
Single-AZ: 50 Mbit/s Dual-AZ or more: 100 Mbit/s |
1000 |
Professional |
4000 |
Single-AZ: 100 Mbit/s Dual-AZ or more: 200 Mbit/s |
1000 |
Enterprise |
6000 |
Single-AZ: 200 Mbit/s Dual-AZ or more: 400 Mbit/s |
1000 |
Platinum |
10,000 |
Single-AZ: 400 Mbit/s Dual-AZ or more: 800 Mbit/s |
1000 |
- For dedicated gateways, you can adjust the maximum number of requests per second for each API.
- The dedicated gateway specifications are tested under the following conditions:
- Protocol: HTTPS
- Connection type: long connection
- Concurrent requests: 100
- Authentication mode: none
- Size of returned data: 1 KB
- Bandwidth: 10 MB/s
