Help Center/
API Gateway/
User Guide (Kuala Lumpur Region)/
API Opening/
VPC Channel Management/
Deleting a VPC Channel
Updated on 2022-08-12 GMT+08:00
You can delete VPC channels you no longer require.
![](https://support.huaweicloud.com/intl/en-us/my-kualalumpur-1-usermanual-apig/public_sys-resources/note_3.0-en-us.png)
VPC channels that are currently in use by published APIs cannot be deleted.
You have created a VPC channel.
- Click
in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Publishing > VPC Channels.
- Delete a VPC channel. You can use one of the following methods:
- In the Operation column of the VPC channel you want to delete, click Delete.
- Click the name of the target VPC channel, and click Delete in the upper right corner of the displayed VPC channel details page.
- Click Yes.
Parent topic: VPC Channel Management
