Help Center>
API Gateway>
User Guide (Kuala Lumpur Region)>
API Calling>
App Management>
Viewing API Details
Updated on 2022-08-12 GMT+08:00
Viewing API Details
You can view the details of an API to which an app has been bound.
- You have created an app.
- The app has been bound to an API.
- Click
in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Calling > Apps.
- Click the name of the target app.
- Click the name of the target API to view its details.
Parent topic: App Management
