Updated on 2022-08-12 GMT+08:00
Deleting an Environment
You can delete environments you no longer require.
You have created an environment.
  2. Click in the upper left corner and choose API Gateway.
  3. In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
  4. In the navigation pane, choose API Publishing > Environments.
  5. In the Operation column of the environment you want to delete, click Delete.
    You can delete an environment only if no APIs have been published in the environment.
  6. Click Yes.
