Help Center>
API Gateway>
User Guide (Kuala Lumpur Region)>
API Opening>
Request Throttling>
Removing an Excluded App or Tenant
Updated on 2022-08-12 GMT+08:00
You can remove excluded apps or tenants from a request throttling policy. This section takes an excluded app as an example.
- You have created a request throttling policy.
- You have already added an excluded app or tenant to the request throttling policy.
- Click
in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Publishing > Request Throttling.
- Click the name of the target request throttling policy.
- Click the Excluded Apps tab on the displayed request throttling policy details page.
- In the Operation column of the app you want to remove, click Remove.
- Click Yes.
Removing an Excluded Tenant
- Click
- Click the Excluded Tenants tab.
- In the Operation column of the tenant you want to remove, click Remove.
- Click Yes.
Parent topic: Request Throttling
