Help Center>
API Gateway>
User Guide (Kuala Lumpur Region)>
API Opening>
API Group Management>
Deleting an API Group
Updated on 2022-08-12 GMT+08:00
You can delete an API group if you do not require it.
![](https://support.huaweicloud.com/intl/en-us/my-kualalumpur-1-usermanual-apig/public_sys-resources/note_3.0-en-us.png)
API groups that contain APIs cannot be deleted.
You have created an API group.
- Click
in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Publishing > API Groups.
- Delete an API group. You can use one of the following methods:
- In the Operation column of the target API group, choose More > Delete.
- Click the name of the target API group, and click Delete Group in the upper right corner of the displayed API group details page.
- Enter DELETE and click Yes.
Parent topic: API Group Management
