Help Center>
API Gateway>
User Guide (Kuala Lumpur Region)>
Getting Started>
Opening APIs>
Publishing an API
Updated on 2022-08-12 GMT+08:00
Publishing an API
- In the navigation pane, choose API Publishing > APIs.
- Locate the API created in Creating an API, and click Publish.
- Select the environment where the API will be published.
- Click Publish.
Parent topic: Opening APIs
