Help Center/
API Gateway/
User Guide (Kuala Lumpur Region)/
Getting Started/
Opening APIs/
(Optional) Creating an Environment
Updated on 2022-08-12 GMT+08:00
- In the navigation pane, choose API Publishing > Environments.
- Click Create Environment and set the environment information.
Table 1 Environment information Parameter
Name
Environment name. It is recommended that you enter a name based on naming rules to facilitate search.
Description of the environment.
- Click OK.
Parent topic: Opening APIs
