Updated on 2026-08-06 GMT+08:00
Cursor
Cursor is a modern AI code editor for developers. It combines the strong features of traditional editors like VS Code with AI-powered smart coding tools. These include smart code completion, natural language programming, and code library understanding, which boost development speed. Cursor also supports popular AI models like OpenAI's GPT-4 and DeepSeek, and offers flexible customization. This makes it ideal for users from beginners to professionals.
MaaS deploys DeepSeek models on its platform, allowing developers use them via API calls.
This guide describes how to use Cursor to call a DeepSeek model deployed in MaaS to build a code editor.
Billing
The built-in services can be used for calling. The services are billed based on the number of tokens used:
You can directly experience or call the model service for inference without waiting for deployment. You are billed based on the number of tokens. For details, see Inference Service Billing Items.
This function is only available in the CN-Hong Kong region.
Step 1: Downloading and Installing Cursor
Download and install Cursor from the official website.
Step 2: Obtaining MaaS DeepSeek Interconnection Information
Obtain key details about the target MaaS DeepSeek model service for connecting with Cursor.
  1. In the navigation pane of the MaaS console, choose Model Inference > Real-time inference.
  2. Click the Built-in Services tab. In the Operation column of the target service, click Subscribe.
  3. In the displayed dialog box, select built-in services as required, select I have read and agree to this statement and MaaS Service Agreement, and click Subscribe.
    Selecting a built-in service will subscribe to all its model versions.
  4. Click View Call Description in the Operation column of the subscribed built-in service. Select a version.
  5. In the View Call Description dialog box, click Create API Key, set related parameters, and click OK.
    API keys are used for API authentication. You can create up to 30 keys. After an API key is created, its tag cannot be changed. Each key is displayed only once after creation. Keep it secure. If the key is lost, it cannot be retrieved. In this case, create a new API key. For details about the API key parameters, see Creating an API Key.
  6. In the Your API Key dialog box, copy the key and store it securely. After the key is saved, click Saved. Confirm and Close.
    After you click Saved. Confirm and Close, the key cannot be viewed again.
  7. Check the API URL and model name in the View Call Description dialog box. You will need these for the next steps in subsequent configuration.
Step 3: Configuring the MaaS API in Cursor
  1. Click the settings icon in the upper right corner of the Cursor platform.
  2. In the Cursor Settings area, choose Models and click Add model.
    Figure 1 Adding a model
  3. Enter the model name obtained in Step 2 in the text box and click Add model on the right.
  4. Select only the added MaaS model. Choosing others might cause the verification to fail.
    Figure 2 Selecting a MaaS model
  5. In the OpenAI Key area, enter the API key created in Step 2.
    Figure 3 Entering the API key
  6. Click Override Openai Base URL. Change the basic API URL to the one obtained from Step 2, and remove /chat/completions at the end. Then click Save.
  7. Click Verify to verify the API connectivity. If no errors show, the setup is complete and you can start using the API.
    Figure 4 Verifying connectivity
Step 4: Using the MaaS API in Cursor to Generate Code
On the code editing page, choose the configured model in the red box for tasks like dialog, code generation, and code parsing.
Figure 5 Using the MaaS API
