Downloading an Agent
Download and then install the agent on the database or application, as required by the add mode you chose.
![](https://support.huaweicloud.com/intl/en-us/eu-west-0-usermanual-dbss/public_sys-resources/note_3.0-en-us.png)
Each agent has a unique ID, which is used as the key for connecting to a database audit instance. If you delete an agent and add it back, you need to download the agent again.
- You have applied for a database audit instance and the Status is Running.
- You have added an agent to the database.
- Select a region, click
, and choose . The Dashboard page is displayed.
- In the navigation tree on the left, choose Databases.
- In the Instance drop-down list, select the instance whose agent is to be downloaded.
- Click
in the lower part of the database list to expand the agent details. Locate the target agent and click Download Agent in the Operation column. to download an agent installation package.
Download the agent installation package suitable for your OS.
