Viewing the Alarms
This section describes how to view and confirm alarms of database audit.
- You have applied for a database audit instance and the Status is Running.
- Database audit has been enabled.
- You have configured alarm notifications.
- In the navigation tree on the left, choose Instances.
- Click the name of an instance, click the Monitoring tab, and then the Alarm Monitoring tab.
- View the alarm information, as shown in Figure 1. For details about related parameters, see Table 1.
    Table 1 Parameters of alarms Parameter Description Time Time when an alarm occurred. Type Alarm type. The options are as follows: - Risky operations
- CPU exceptions
- Memory exceptions
- Disk exceptions
- Insufficient audit log storage
 Alarm Risk Severity Risk severity of an alarm. The options are as follows: - High
- Moderate
- Low
 Cleared Time when an alarm is cleared Confirmed Or Not Confirmation status of an alarm. Click  to filter alarms in Unconfirmed or Confirmed state. to filter alarms in Unconfirmed or Confirmed state.Description Description of an alarm To query specified alarms, perform the following steps:- Select Last 30 minutes, 1 hour, 24 hours, 7 days, or 30 days for Time, and click  to view alarms of the specified time range. to view alarms of the specified time range.
- Select All, High, Moderate, or Low for Risk Severity. Alarms of specified severity are displayed in the list.
- Select an alarm type, and alarms of specified alarm type is displayed in the list.
Follow-Up Procedure
    You can select multiple alarms to be confirmed and click Batch Confirm to batch confirm alarms.
