Managing Databases and Agents
Updated on 2024-01-12 GMT+08:00
After adding a database successfully, you can view, disable or delete the database. After adding an agent to the database, you can view, disable or delete the agent.
  • You have applied for a database audit instance and the Status is Running.
  • You have added a database successfully.
  • Before disabling a database, ensure that Audit Status of the database is Enabled.
Viewing the Database Information
  2. Select a region, click , and choose Security > Database Security Service. The Dashboard page is displayed.
  3. In the navigation tree on the left, choose Databases.
  4. In the Instance drop-down list, select the instance whose database you want to view.
  5. View the database information. For details about related parameters, see Table 1.
    Figure 1 Viewing the database and agent information
    Select an audit status from the All audit statuses drop-down list in the upper right corner of the list, or enter a key word of a database to search for it.
    Table 1 Parameters
    Example Value
    Name, type, and version of a database
    Character Set
    Encoding character set of the database
    UTF8
    IP Address/Port
    IP address of the database
    192.168.0.104
    3306
    Instance
    Database instance name
    OS
    Operating system of the database
    LINUX64
    Audit Status
    Audit status of the database. The options are as follows:
    • Enabled
    • Disabled
    Enabled
    Agent
    Click Add to add an agent for the database.
    Add an agent.
    You can perform the following operations on a database you added:
    • Disable
      • Locate the row that contains the database to be disabled, click Disable in the Operation column, and click OK in the displayed dialog box. The Audit Status of the database will change to Disabled.
      • When a database is disabled, database audit is disabled for the database.
    • Delete
      • Locate the row that contains the database to be deleted, click Delete in the Operation column, and click OK in the displayed dialog box.
      • You need to add the database again if a database is deleted and you want to audit the database.
Viewing an Agent
  4. In the Instance drop-down list, select the instance whose agent you want to view.
  5. Click on the left of the database to expand the agent details, as shown in Figure 2. For details about related parameters, see Table 2.
    Figure 2 Viewing the database and agent information
    Table 2 Parameters of an agent
    Agent ID
    Agent ID, which is automatically generated
    Installing Node Type
    Type of the installing node. The options are Database and Application.
    Installing Node IP Address
    IP address of the node where an agent is installed
    OS
    Agent OS
    Audited NIC Name
    NIC name of an installing node
    CPU Threshold (%)
    CPU threshold of the installing node. The default value is 80.
    The agent on a node will stop working if the CPU usage of the node exceeds this threshold. You can scale up CPU resources to avoid this problem.
    Memory Threshold (%)
    Memory threshold of the installing node. The default value is 80.
    The agent on a node will stop working if the memory usage of the node exceeds this threshold. You can scale up memory resources to avoid this problem.
    General
    Whether an agent is a general-purpose agent.
    Status
    Running status of the installing node
    You can perform the following operations on an agent you added:
    • Disable
      • Locate the row that contains the agent to be disabled, click Disable in the Operation column, and click OK in the displayed dialog box. The status of the agent will change to Disabled.
      • When an agent is disabled, database audit is disabled for the associated database.
    • Delete
      • Locate the row that contains the agent to be deleted, click Delete in the Operation column, and click OK in the displayed dialog box.
      • After an agent is deleted, add another agent again if you want to audit the database.
