On this page
Step 1: Add a Database
Updated on 2024-01-12 GMT+08:00
Database audit supports databases built on ECS, BMS, and RDS on the console. After applying for a database audit instance, you need to add the database to be audited to the instance.
You have applied for a database audit instance and the Status is Running.
Adding a Database
  2. Select a region, click , and choose Security > Database Security Service. The Dashboard page is displayed.
  3. In the navigation tree on the left, choose Databases.
  4. In the Instance drop-down list, select the instance whose database is to be added.
  5. Click Add Database.
  6. In the dialog box displayed, set the database information. In the dialog box displayed, set the database information. For details about related parameters, see Table 1.
    Table 1 Parameters
    Example Value
    Name
    Custom name of the database to be added
    test1
    IP Address
    IP address of the database to be added.
    The IP address must be an internal IP address in IPv4 or IPv6 format.
    IPv4: 192.168.1.1
    IPv6: fe80:0000:0000:0000:0000:0000:0000:0000
    Type
    Supported database type. The options are as follows:
    • MYSQL
    • ORACLE
    • POSTGRESQL
    • SQLSERVER
    • DWS
    • GaussDB for MYSOL
    • GaussDB
    • DAMENG
    • KINGBASE
    • SHENTONG
    • GBase 8a
    • GBase XDM Cluster
    • Greenplum
    • HighGo
    • Mariadb
    If ORACLE is selected, to make the audit settings take effect, restart the applications to be audited and log in to the database again.
    MYSQL
    Port
    Port number of the database to be added
    3306
    Version
    Supported database versions
    • When Type is set to MYSQL, the following versions are available:
    • When Type is set to ORACLE, the following versions are available:
      • 11g
      • 12c
      • 19c
    • When Type is set to POSTGRESQL, the following versions are available:
      • 7.4
      • 8.0
        8.0, 8.1, 8.2, 8.3, 8.4
      • 9.0
        9.0, 9.1, 9.2, 9.3, 9.4, 9.5, 9.6
      • 10.0
        10.0, 10.1, 10.2, 10.3, 10.4, 10.5
      • 11.0
      • 12.0
      • 13.0
    • When Type is set to SQLSERVER, the following versions are available:
      • 2008
      • 2012
      • 2014
      • 2016
      • 2017
    • When Type is set to DWS, the following versions are available:
      • 1.5
    • When Type is set to GaussDB for MySQL, the following version is available:
      • MySQL 8.0
    • When Type is set to GaussDB, the following version is available:
      • 1.4 Enterprise Edition
    • When Type is set to DAMENG, the following version is available:
      • DM8
    • When Type is set to KINGBASE, the following version is available:
      • V8
    5.0
    Instance
    Instance name of the database to be audited
    • If you do not configure the Instance field, database audit will audit all instances in the database.
    • If you enter an instance name, database audit will audit the entered instance. Enter a maximum of five instance names and use semicolons (;) to separate instance names.
    Character Set
    Encoding format of the database character set. The options are as follows:
    • UTF-8
    • GBK
    UTF-8
    OS
    OS of the added database. The options are as follows:
    • LINUX64
    • WINDOWS64
    LINUX64
    Database Type
    Type of the database to be added. Its value can be RDS database or Self-built database.
    RDS database
  7. Click OK. Then a database in the Disabled state has been added to the database list. See Figure 1.
    Figure 1 Successfully adding a database
    • After adding the database, confirm that the database information is correct. If the database information is incorrect, locate the target database and click Delete in the Operation column, and add the database again.
