Help Center/
      Database Security Service/
        User Guide (Paris and Amsterdam Regions)/
      Viewing Tracing Logs
        Updated on 2024-01-12 GMT+08:00
After you enable CTS, the system starts recording operations on DBSS. Operation records for the last seven days can be viewed on the CTS console.
Viewing a DBSS Trace on the CTS Console
 - In the navigation pane on the left, click
 and choose Management & Deployment > Cloud Trace Service. - Choose Trace List in the navigation pane.
 - Click Region at the top of the Trace List page to set the corresponding conditions.
    The following four filters are available:
- Trace Type, Trace Source, Resource Type, and Search By
- Select the filter from the drop-down list. Set Trace Source to DBSS.
 - When you select Trace name for Search By, you also need to select a specific trace name.
 - When you select Resource ID for Search By, you also need to select or enter a specific resource ID.
 - When you select Resource name for Search By, you also need to select or enter a specific resource name.
 - Operator: Select a specific operator (a user other than tenant).
 - Trace Rating: Available options include All trace status, normal, warning, and incident. You can only select one of them.
 - In the upper right corner of the page, you can query traces in the last 1 hour, last 1 day, last 1 week, or within a customized period.
 - Click Query.
 - Click
 on the left of a trace to expand its details.
    Figure 1 Expanding trace details
     - Click View Trace in the Operation column. On the displayed View Trace dialog box shown in Figure 2, the trace structure details are displayed.
