Help Center/
Cloud Container Engine/
User Guide (Paris Regions)/
Clusters/
Upgrading a Cluster/
Performing Post-Upgrade Verification/
New Node Check
New Node Check
Check Items
Check whether nodes can be created in the cluster.
- In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab and then Create Node. For details about the node configuration, see Creating a Node.
Solution
If nodes cannot be created in your cluster after the cluster is upgraded, contact technical support.
Parent topic: Performing Post-Upgrade Verification
