Upgrade Management
Check Items
Check whether the target cluster is under upgrade management.
Solution
CCE may temporarily restrict the cluster upgrade due to the following reasons:
  • The cluster is identified as the core production cluster.
  • Other O&M tasks are being or will be performed, for example, 3-AZ reconstruction on master nodes.
To resolve this issue, contact technical support.
