Updated on 2025-06-13 GMT+08:00
Workload FAQs
Abnormal Workload Status
- If the workload is in the Not ready state, you can view pod events or other information to locate the fault and find the solution based on the events. For details, see How Can I Locate the Root Cause If a Workload Is Abnormal?
- If the workload is in the Processing state, wait patiently.
- If the workload is in the Running state, no action is required. If the workload status is normal but it cannot be accessed, check whether intra-cluster access is normal.
Workload Log/Monitoring Exception
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
