Changing the DataNode Storage Directory
   This section applies to MRS 3.x or later.
If the storage directory defined by the HDFS DataNode is incorrect or the HDFS storage plan changes, the MRS cluster administrator needs to modify the DataNode storage directory on FusionInsight Manager to ensure smooth HDFS running. Changing the ZooKeeper storage directory includes the following scenarios:
- Change the storage directory of the DataNode role. In this way, the storage directories of all DataNode instances are changed.
 - Change the storage directory of a single DataNode instance. In this way, only the storage directory of this instance is changed, and the storage directories of other instances remain the same.
Impact on the System
- The HDFS service needs to be stopped and restarted during the process of changing the storage directory of the DataNode role, and the cluster cannot provide services before it is completely started.
- The DataNode instance needs to stopped and restarted during the process of changing the storage directory of the instance, and the instance at this node cannot provide services before it is started.
 - The directory for storing service parameter configurations must also be updated.
- New disks have been prepared and installed on each data node, and the disks are formatted.
- New directories have been planned for storing data in the original directories.
 - The HDFS client has been installed.
 - The service user hdfs has been created.
 - When changing the storage directory of a single DataNode instance, ensure that the number of active DataNode instances is greater than the value of dfs.replication.
Check the environment.
- Log in to the server where the HDFS client is installed as user root, and run the following command to configure environment variables:
source Installation directory of the HDFS client/bigdata_env
 - If the cluster is in security mode, run the following command to authenticate the user:
kinit hdfs
 - Run the following command on the HDFS client to check whether all directories and files in the HDFS root directory are normal:
hdfs fsck /
Check the fsck command output.
 - Log in to FusionInsight Manager, choose Cluster > Services, and check whether Running Status of HDFS is Normal.
 - Rectify the HDFS fault. The task is complete.
 - Determine whether to change the storage directory of the DataNode role or that of a single DataNode instance:
Changing the storage directory of the DataNode role
- Choose Cluster > Services > HDFS and click Stop Service to stop the HDFS service.
 - Log in as user root to each node on which the HDFS service is installed, and perform the following operations:
- Create a target directory (data1 and data2 are original directories in the cluster).
For example, if the target directory is ${BIGDATA_DATA_HOME}/hadoop/data3/dn, run the following command:
mkdir -p ${BIGDATA_DATA_HOME}/hadoop/data3/dn
 - Mount the target directory to the new disk. For example, mount ${BIGDATA_DATA_HOME}/hadoop/data3 to the new disk.
 - Modify permissions on the new directory.
For example, if the new directory is ${BIGDATA_DATA_HOME}/hadoop/data3/dn, run the following command:
chmod 700 ${BIGDATA_DATA_HOME}/hadoop/data3/dn -R
chown omm:wheel ${BIGDATA_DATA_HOME}/hadoop/data3/dn -R
 - Copy the data to the target directory.
For example, if the original directory is ${BIGDATA_DATA_HOME}/hadoop/data1/dn and the target directory is ${BIGDATA_DATA_HOME}/hadoop/data3/dn, run the following command:
cp -af ${BIGDATA_DATA_HOME}/hadoop/data1/dn/* ${BIGDATA_DATA_HOME}/hadoop/data3/dn
 - On FusionInsight Manager, choose Cluster > Services > HDFS and click Configurations then All Configurations to access the HDFS service configuration page.
Change the value of dfs.datanode.data.dir from the default value %{@auto.detect.datapart.dn} to the new target directory, for example, ${BIGDATA_DATA_HOME}/hadoop/data3/dn.
For example, the original data storage directories are /srv/BigData/hadoop/data1, /srv/BigData/hadoop/data2. To migrate data from the /srv/BigData/hadoop/data1 directory to the newly created /srv/BigData/hadoop/data3 directory, replace the whole parameter with /srv/BigData/hadoop/data2, /srv/BigData/hadoop/data3. Separate multiple storage directories with commas (,). In this example, changed directories are /srv/BigData/hadoop/data2, /srv/BigData/hadoop/data3.
 - Click Save. On the Cluster > Services page, start each stopped service in the cluster.
 - After the HDFS is started, run the following command on the HDFS client to check whether all directories and files in the HDFS root directory are correctly copied:
hdfs fsck /
- If the following information is displayed, no file is lost or damaged, and data replication is successful. No further action is required.
The filesystem under path '/' is HEALTHY
 - If other information is displayed, some files are lost or damaged. Check whether 8.d is correct and run the following command:
hdfs fsck Name of the damaged file -delete
Changing the storage directory of a single DataNode instance
- Choose Cluster > Services > HDFS and click Instances. Select the DataNode whose storage directory needs to be modified, click More, and select Stop Instance.
 - Log in to the DataNode node as user root, and perform the following operations:
- Create a target directory.
 - On FusionInsight Manager, choose Cluster > Services > HDFS and click Instance. Click the specified DataNode instance and go to the Configurations tab page.
For example, the original data storage directories are /srv/BigData/hadoop/data1,/srv/BigData/hadoop/data2. To migrate data from the /srv/BigData/hadoop/data1 directory to the newly created /srv/BigData/hadoop/data3 directory, replace the whole parameter with /srv/BigData/hadoop/data2,/srv/BigData/hadoop/data3.
 - Click Save, and then click OK.
Operation succeeded is displayed. click Finish.
 - Choose More > Restart Instance to restart the DataNode instance.
