Special Billing Scenarios
Lifecycle Rules
If you configure lifecycle rules to perform actions automatically, you will be billed. The following tables list billable items and their descriptions.
For detailed information about billing items, see Overview.
Action |
Billing Category |
Description |
Delete after expiration |
Requests |
You are charged for the number of successfully deleted objects. |
Storage space |
If objects are deleted before they have been stored for the required minimum duration (30 days for Warm storage and 90 days for Cold storage), you will still be billed for a full 30 or 90 days. |
Transition from Standard to Warm |
Requests |
You are charged for the number of successfully transitioned objects. If N objects are successfully transitioned, you are billed for N requests. |
Transition from Standard to Cold |
Requests |
Transition from Warm to Cold |
Requests |
Action |
Billing Category |
Description |
None |
None |
Storage space |
After the transition, object storage fees are calculated based on the Warm storage price. |
Data retrieval |
After the transition, retrieving Warm objects will be charged based on the object size. |
Storage space |
After the transition, object storage fees are calculated based on the Cold storage price. |
Data retrieval |
After the transition, retrieving Cold objects will be charged based on the object size and restoration speed. |
Storage space |
Data retrieval |
