Protecting a CCE Cluster Against Overload
As services grow, the Kubernetes cluster scales up, putting more pressure on the control plane. If the control plane cannot handle the load, clusters may fail to provide services. This document explains the symptoms, impact, and causes of cluster overload, as well as how CCE clusters can protect against overload. It also provides recommended measures for protecting against overload.
What Is Cluster Overload?
An overloaded cluster can cause delays in Kubernetes API responses and increase the resource usage on master nodes. In severe cases, the APIs may fail to respond, master nodes may become unusable, and the entire cluster may malfunction.
When a cluster is overloaded, both the control plane and the services that rely on it are impacted. The following lists some scenarios that may be affected:
  • Kubernetes resource management: Creating, deleting, updating, or obtaining Kubernetes resources may fail.
  • Kubernetes distributed leader selection: In distributed applications based on Kubernetes Leases, leaders may restart due to lease renewal request timeout.
    For example, if the lease renewal of the controller component of the NPD add-on fails, an active/standby switchover is triggered. This means that the active instance will restart, and the standby instance will take over services, ensuring that there is no impact on services.
  • Cluster management: When a cluster is severely overloaded, it may become unavailable. In this case, cluster management operations, such as creating or deleting nodes, cannot be performed.
Common causes of cluster overload are as follows:
  • The cluster resource data volume is too large.
    etcd and kube-apiserver are two core components of the cluster control plane. etcd serves as the background database that stores all cluster data, while kube-apiserver acts as the entry point for processing requests. kube-apiserver caches cluster data to lessen the burden on etcd, and other core components in the cluster also cache various resources and monitor changes to these resources.
    However, if the cluster resource data volume is too large, the control plane resource usage remains high, leading to overload when the resource data volume exceeds the bearing capability.
  • A large amount of data is obtained from a client. For example, a large number of LIST requests are initiated or a single LIST request is sent to obtain a large amount of data.
    Assume that a client uses field selectors to obtain pod data in a cluster and needs to obtain data from etcd (although the client can also get data from the kube-apiserver cache). Data in etcd cannot be obtained by field, so kube-apiserver must get all pod data from etcd, replicate, and serialize structured pod data, and then respond to the client request.
    When the client sends a LIST request, it may need to be processed by multiple control plane components, resulting in a larger amount of data to be processed and a more complex data type. As a result, when the client gets a large amount of data, resource usages on etcd and API server remain high. If the bearing capability is exceeded, the cluster becomes overloaded.
CCE Overload Control
  • Overload control: CCE clusters have supported overload control since v1.23, which reduces the number of LIST requests outside the system when the control plane experiences high resource usage pressure. To use this function, enable overload control for your clusters. For details, see Enabling Overload Control for a Cluster.
  • Optimized processes on LIST requests: Starting from CCE clusters of v1.23.8-r0 and v1.25.3-r0, processes on LIST requests have been optimized. Even if a client does not specify the resourceVersion parameter, kube-apiserver responds to requests based on its cache to avoid additional etcd queries and ensure that the response data is up to date. Additionally, namespace indexes are now added to the kube-apiserver cache. This means that when a client requests a specified resource in a specified namespace, it no longer needs to obtain resources belonging to the namespace based on full data. This effectively reduces the response delay and control plane memory overhead.
  • Refined traffic limiting policy on the server: The API Priority and Fairness (APF) feature is used to implement fine-grained control on concurrent requests. For details, see API Priority and Fairness.
Suggestions
This section describes measures and suggestions you can take to prevent clusters from being overloaded.
Summary
When running services on Kubernetes clusters, their performance and availability are influenced by various factors, including the cluster scale, number and size of resources, and resource access. CCE has optimized cluster performance and availability based on cloud native practices and has developed measures to protect against cluster overload. You can use these measures to ensure that your services run stably and reliably over the long term.
