Patch Version Release Notes
Version 1.29
Table 1 Release notes for the v1.29 patch
CCE Cluster Patch Version
Kubernetes Version
Feature Updates
Optimization
Vulnerability Fixing
v1.29.2-r0
v1.29.3
  • CCE ingresses support traffic distribution based on custom HTTP headers.
  • Scaling priority policies can be configured for third-party workloads.
  • You can configure a security group for a pod using annotations. This feature is only available for CCE Turbo clusters.
  • You can bind an existing EIP to a pod. This feature is only available for CCE Turbo clusters.
  • An in-progress node drainage can be canceled.
  • When updating a node pool, you can change its agency name, prefix, and suffix.
  • Kubernetes labels and taints of a node are retained after the node is reset.
  • Both the Kubernetes service account token volume projection and the load scaling controller can be configured.
Fixed some security issues.
v1.29.1-r0
v1.29.1
CCE clusters of v1.29 are released for the first time. For more information, see Kubernetes 1.29 Release Notes.
None
None
Version 1.28
Table 2 Release notes for the v1.28 patch
Kubernetes Version
Feature Updates
Optimization
v1.28.6-r0
v1.28.8
v1.28.3-r0
v1.28.3
LoadBalancer Services and ingresses allow you to:
  • Configure SNI.
  • Enable HTTP/2.
  • Configure idle timeout, request timeout, and response timeout.
None
v1.28.2-r0
v1.28.3
  • You can configure an ELB blocklist/trustlist for access control when creating a Service or ingress.
None
v1.28.1-r4
v1.28.3
None
None
Fixed CVE-2024-21626 issues.
v1.28.1-r0
v1.28.3
CCE clusters of v1.28 are released for the first time. For more information, see Kubernetes 1.28 Release Notes.
  • The prefix and suffix of a node name can be customized in node pools.
  • In CCE Turbo clusters, you can create container networks for workloads and specify pod subnets.
  • LoadBalancer ingresses support gRPC.
  • LoadBalancer Services allow you to specify a private IP address for a load balancer during Service creation using YAML.
  • Accelerated the startup speed for creating a large number of Kata containers in a CCE Turbo cluster.
  • Improved the stability when Kata containers are repeatedly created or deleted in a CCE Turbo cluster.
None
Version 1.27
Table 3 Release notes for the v1.27 patch
Kubernetes Version
Feature Updates
Optimization
v1.27.8-r0
v1.27.12
v1.27.5-r0
v1.27.4
  • Configure SNI.
  • Enable HTTP/2.
None
v1.27.3-r4
v1.27.4
None
None
v1.27.2-r0
v1.27.2
  • Volcano supports node pool affinity scheduling.
  • Volcano supports workload rescheduling.
None
v1.27.1-r10
v1.27.2
None
Optimized the events generated during node pool scaling.
v1.27.1-r0
v1.27.2
CCE clusters of v1.27 are released for the first time. For more information, see Kubernetes 1.27 Release Notes.
  • Both soft eviction and hard eviction are supported in node pool configurations.
None
None
Version 1.25
In CCE clusters of v1.25, containerd is the default runtime for nodes, except for nodes running EulerOS 2.5. In addition, clusters of v1.25 or later no longer support EulerOS 2.5.
Table 4 Release notes for the v1.25 patch
Kubernetes Version
Feature Updates
Optimization
v1.25.11-r0
v1.25.16
v1.25.8-r0
v1.25.10
  • Configure SNI.
  • Enable HTTP/2.
None
v1.25.6-r4
v1.25.10
None
None
v1.25.5-r0
v1.25.5
None
v1.25.4-r10
v1.25.5
None
v1.25.4-r0
v1.25.5
  • TMS tags can be added to automatically created EVS disks to facilitate cost management.
None
v1.25.3-r10
v1.25.5
The timeout interval can be configured for a load balancer.
High-frequency parameters of kube-apiserver are configurable.
v1.25.3-r0
v1.25.5
None
Enhanced network stability of CCE Turbo clusters when their specifications are modified.
v1.25.1-r0
v1.25.5
CCE clusters of v1.25 are released for the first time. For more information, see Kubernetes 1.25 Release Notes.
None
None
Version 1.23
Table 5 Release notes for the v1.23 patch
Kubernetes Version
Feature Updates
Optimization
v1.23.16-r0
v1.23.17
v1.23.13-r0
v1.23.17
  • Configure SNI.
  • Enable HTTP/2.
None
v1.23.11-r4
v1.23.17
None
None
v1.23.10-r0
v1.23.11
None
v1.23.9-r10
v1.23.11
None
v1.23.9-r0
v1.23.11
None
v1.23.8-r10
v1.23.11
v1.23.8-r0
v1.23.11
None
  • Enhanced Docker reliability during upgrades.
  • Optimized node time synchronization.
v1.23.5-r0
v1.23.11
  • Fault detection and isolation are supported on GPU nodes.
  • Security groups can be customized by cluster.
  • CCE Turbo clusters support ENIs pre-binding by node.
  • containerd is supported.
  • Upgraded the etcd version of the master node to the Kubernetes version 3.5.6.
  • Optimized scheduling so that pods are evenly distributed across AZs after pods are scaled in.
  • Optimized the memory usage of kube-apiserver when CRDs are frequently updated.
Fixed some security issues and the following CVE vulnerabilities:
v1.23.1-r0
v1.23.4
CCE clusters of v1.23 are released for the first time. For more information, see Kubernetes 1.23 Release Notes.
None
None
Version 1.21
Table 6 Release notes for the v1.21 patch
Kubernetes Version
Feature Updates
Optimization
v1.21.14-r0
v1.21.14
A PVC can be used to dynamically create and mount an SFS Turbo subdirectory.
None
v1.21.12-r4
v1.21.14
None
None
v1.21.11-r20
v1.21.14
None
v1.21.11-r10
v1.21.14
None
v1.21.11-r0
v1.21.14
None
v1.21.10-r10
v1.21.14
v1.21.10-r0
v1.21.14
None
  • Enhanced the stability of the Docker runtime for pulling images after nodes are restarted.
v1.21.7-r0
v1.21.14
Improved the stability of LoadBalancer Services/ingresses with a large number of connections.
v1.21.1-r0
v1.21.7
CCE clusters of v1.21 are released for the first time. For more information, see Kubernetes 1.21 Release Notes.
None
None
Version 1.19
Table 7 Release notes for the v1.19 patch
Kubernetes Version
Feature Updates
Optimization
1.19.16-r84
v1.19.16
None
None
v1.19.16-r60
v1.19.16
None
v1.19.16-r50
v1.19.16
None
v1.19.16-r40
v1.19.16
None
v1.19.16-r30
v1.19.16
v1.19.16-r20
v1.19.16
None
  • Cloud Native 2.0 Networks allow you to specify subnets for a namespace.
  • Optimized the performance of CCE Turbo clusters in allocating ENIs if not all ENIs are pre-bound.
v1.19.16-r4
v1.19.16
  • Scheduling is optimized on taint nodes.
  • Enhanced the long-term running stability of containerd when cores are bound.
  • Improved the stability of LoadBalancer Services/ingresses with a large number of connections.
v1.19.16-r0
v1.19.16
None
Enhanced the stability in updating LoadBalancer Services when workloads are upgraded and nodes are scaled in or out.
v1.19.10-r0
v1.19.10
CCE clusters of v1.19 are released for the first time. For more information, see Kubernetes 1.19 Release Notes.
None
None
