VPC Network Model
Model Definition
The VPC network model seamlessly combines VPC routing with the underlying network, making it ideal for high-performance scenarios. However, the maximum number of nodes allowed in a cluster is determined by the VPC route quota. In the VPC network model, container CIDR blocks are separate from node CIDR blocks. To allocate IP addresses to containers running on a node in a cluster, each node in the cluster is allocated with a container CIDR block for a fixed number of IP addresses. The VPC network model outperforms the container tunnel network model in terms of performance because it does not have tunnel encapsulation overhead. When using the VPC network model in a cluster, the VPC route table automatically configures the routes between container CIDR blocks and VPC CIDR blocks. This means that pods within the cluster can be accessed directly from cloud servers in the same VPC, even if they are outside the cluster.
Figure 1 VPC network model
In a cluster using the VPC network model, network communication paths are as follows:
  • Inter-pod communication on the same node: Packets are directly forwarded through IPvlan.
  • Inter-pod communication on different nodes: The traffic accesses the default gateway by following the route specified in the VPC route table and then is forwarded to the target pod on another node using VPC routing.
  • Pod communication with the Internet: When a container in a cluster needs to access the Internet, CCE uses NAT to translate the container's IP address into the node IP address so that the pod communicates externally using the node IP address.
Advantages and Disadvantages
Advantages
  • High performance and simplified network fault locating are achieved by eliminating the need for tunnel encapsulation.
  • A VPC route table automatically configures routes between container CIDR blocks and VPC CIDR blocks. This enables resources in the VPC to directly communicate with containers in the cluster.
    Similarly, if the VPC is accessible to other VPCs or data centers and the VPC route table includes routes to the container CIDR blocks, resources in other VPCs or data centers can directly communicate with containers in the cluster, provided there are no conflicts between the network CIDR blocks.
Disadvantages
  • The number of nodes is limited by the VPC route quota.
  • Each node is assigned a CIDR block with a fixed size, which results in IP address wastage in the container CIDR block.
  • Pods cannot directly use features like EIPs and security groups.
Application Scenarios
  • High performance requirements: As no tunnel encapsulation is required, the VPC network model delivers the performance close to that of a VPC network when compared with the container tunnel network model. Therefore, the VPC network model applies to scenarios that have high requirements on performance, such as AI computing and big data computing.
  • Small- and medium-scale networks: Due to the limitation on VPC route tables, it is recommended that the number of nodes in a cluster be less than or equal to 1000.
Container IP Address Management
The VPC network model assigns container IP addresses based on the following guidelines:
  • Container CIDR blocks are separate from node CIDR blocks.
  • IP addresses are allocated by node. One CIDR block with a fixed size (configurable) is allocated to each node in a cluster from the container CIDR block.
  • A container CIDR block assigns CIDR blocks to new nodes in a cyclical sequence.
  • IP addresses from the CIDR blocks assigned to a node are allocated to pods scheduled to that node in a cyclical manner.
Figure 2 IP address management of the VPC network
Maximum number of nodes that can be created in the cluster using the VPC network = Number of IP addresses in the container CIDR block/Number of IP addresses in the CIDR block allocated to the node by the container CIDR block
For example, if the container CIDR block is 172.16.0.0/16, the number of IP addresses is 65536. The mask of the container CIDR block allocated to a node is 25. That is, the number of container IP addresses on each node is 128. Therefore, a maximum of 512 (65536/128) nodes can be created. The number of nodes that can be added to a cluster is also determined by the available IP addresses in the node subnet and the scale of the cluster. For details, see Recommendation for CIDR Block Planning.
As explained in Cluster Network Structure, network addresses in a cluster are divided into the cluster network, container network, and service network. When planning network addresses, consider the following factors:
  • The three CIDR blocks cannot overlap. Otherwise, a conflict occurs.
  • Ensure that each CIDR block has sufficient IP addresses.
    • The IP addresses in the cluster CIDR block must match the cluster scale. Otherwise, nodes cannot be created due to insufficient IP addresses.
    • The IP addresses in the container CIDR block must match the service scale. Otherwise, pods cannot be created due to insufficient IP addresses. The number of pods that can be created on each node also depends on other parameter settings.
Assume that a cluster contains 200 nodes and the network model is VPC network.
In this case, the number of available IP addresses in the selected subnet must be greater than 200. Otherwise, nodes cannot be created due to insufficient IP addresses.
The container CIDR block is 172.16.0.0/16, and the number of available IP addresses is 65536. As described in Container IP Address Management, the VPC network is allocated a CIDR block with a fixed size (using the mask to determine the maximum number of container IP addresses allocated to each node). For example, if the upper limit is 128, the cluster supports a maximum of 512 (65536/128) nodes.
Example of VPC Network Access
In this example, a cluster using the VPC network model is created, and the cluster contains one node.
On the VPC console, locate the VPC to which the cluster belongs and check the VPC route table.
You can find that CCE has created a custom route in the route table. This route has a destination address corresponding to the container CIDR block assigned to the node, and the next hop is directed towards the target node. In the example, the container CIDR block for the cluster is 172.16.0.0/16, with 128 container IP addresses assigned to each node. Therefore, the node's container CIDR block is 172.16.0.0/25, providing a total of 128 container IP addresses.
When a container IP address is accessed, the VPC route will forward the traffic to the next-hop node that corresponds to the destination address. The following is an example:
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a Deployment in the cluster.
    Create the deployment.yaml file. The following shows an example:
    kind: Deployment
    apiVersion: apps/v1
      namespace: default
      replicas: 4
      selector:
        matchLabels:
          app: example
      template:
          labels:
            app: example
          containers:
            - name: container-0
              image: 'nginx:perl'
          imagePullSecrets:
            - name: default-secret
    Create the workload.
    kubectl apply -f deployment.yaml
  3. Check the running pods.
    kubectl get pod -owide
    Command output:
    NAME                       READY   STATUS    RESTARTS   AGE   IP           NODE           NOMINATED NODE   READINESS GATES
    example-86b9779494-l8qrw   1/1     Running   0          14s   172.16.0.6   192.168.0.99   <none>           <none>
    example-86b9779494-svs8t   1/1     Running   0          14s   172.16.0.7   192.168.0.99   <none>           <none>
    example-86b9779494-x8kl5   1/1     Running   0          14s   172.16.0.5   192.168.0.99   <none>           <none>
    example-86b9779494-zt627   1/1     Running   0          14s   172.16.0.8   192.168.0.99   <none>           <none>
  4. Use a cloud server in the same VPC to directly access a pod's IP address from outside the cluster. You can also access a pod using its IP address within the pod or from a node in the cluster. In the following example, access a pod's IP address within the pod. example-86b9779494-l8qrw is the pod name, and 172.16.0.7 is the pod IP address.
    kubectl exec -it example-86b9779494-l8qrw -- curl 172.16.0.7
    If the following information is displayed, the workload can be properly accessed:
    <!DOCTYPE html>
    <html>
    <head>
    <title>Welcome to nginx!</title>
    <style>
        body {
            width: 35em;
            margin: 0 auto;
            font-family: Tahoma, Verdana, Arial, sans-serif;
    </style>
    </head>
    <body>
    <h1>Welcome to nginx!</h1>
    <p>If you see this page, the nginx web server is successfully installed and
    working. Further configuration is required.</p>
    <p>For online documentation and support please refer to
    <a href="http://nginx.org/">nginx.org</a>.<br/>
    Commercial support is available at
    <a href="http://nginx.com/">nginx.com</a>.</p>
    <p><em>Thank you for using nginx.</em></p>
    </body>
    </html>
