Help Center/ Blockchain Service/ User Guide (ME-Abu Dhabi Region)/ Managing Enhanced Hyperledger Fabric Instances/ Instance Management/ O&M Center/ Viewing Chaincode Debug Logs
Updated on 2023-03-07 GMT+08:00
You can view chaincode debug logs to analyze and locate problems. This section describes how to view chaincode debug logs on the CCE console.
- Log in to the CCE console.
- In the navigation pane, choose Workloads > Deployments. Select the cluster where the BCS instance is deployed.
- Click the workload whose name starts with baas-agent.
- Click Logs in the upper right corner to view the logs of the chaincode container. To view more logs or export logs, go to the AOM console. Figure 1 Viewing the chaincode pod logs
Parent topic: O&M Center
