Updated on 2023-05-09 GMT+08:00
Process Flow
The following figure shows the process of exposing an API.
  1. Creating a Gateway
    Buy a gateway.
  2. Creating an API Group
    An API group facilitates management of APIs used for the same service. Create an API group and then create APIs.
  3. Binding a Domain Name
    Before making the API available for users to access, bind an independent domain name (custom domain name) to the group to which the API belongs. Then API callers can use these domain names to call the API.
  4. Creating an API
    When creating an API, configure the frontend and backend request paths, parameters, and protocols.
  5. Debugging an API
    Debug the API to check whether it works normally.
  6. (Optional) Creating an Environment
    An API can be called in different scenarios, such as the production environment (RELEASE) or other custom environments. RELEASE is the default environment defined in APIG.
  7. Publishing an API
    Publish the API so that it can be called.
