- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
Show all
RDS.Volume
Property Description
Property |
Mandatory |
Type |
Description |
volumetype |
Yes |
Cloud.RDS.Volume.Type.Name |
Disk type Value Description: The options are COMMON (SATA), HIGH (SAS), and ULTRAHIGH (SSD). These values are case sensitive. Value Constraint: Set the value based on requirements. Suggestion: Set the value based on specifications. |
size |
Yes |
integer |
Disk size Value Description: The value ranges from 40 to 4000. Unit: GB. Value Constraint: The value ranges from 40 to 4000. The value must be an integer multiple of 10. Suggestion: Set the value based on specifications. |
