months_between
This function returns the month difference between date1 and date2.
Syntax
months_between(string date1, string date2)
Parameters
Parameter |
Mandatory |
Type |
Description |
date1 |
Yes |
DATE or STRING |
Minuend
The following formats are supported:
date2 |
Yes |
DATE or STRING |
Subtrahend
Return Values
The return value is of the DOUBLE type.
- If the values of date1 and date2 are not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the values of date1 and date2 are of the DATE or STRING type but are not in one of the supported formats, NULL is returned.
- If date1 is later than date2, the return value is positive. If date2 is later than date1, the return value is negative.
- If date1 and date2 correspond to the last day of two different months, an integer month is returned. Otherwise, the calculation is based on the number of days between date1 and date2 divided by 31.
- If the value of date1 or date2 is NULL, NULL is returned.
Example Code
The value 0.0563172 is returned.
select months_between('2023-08-16 10:54:00', '2023-08-14 17:00:00');
The value 0.06451613 is returned.
select months_between('2023-08-16','2023-08-14');
The value NULL is returned.
select months_between('2023-08-16',null);
