conv
Updated on 2023-10-25 GMT+08:00
This function is used to convert a number from from_base to to_base.
Syntax
conv(BIGINT num, INT from_base, INT to_base)
Parameters
Table 1 Parameters
Mandatory
Type
num
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
Number whose base needs to be converted
The value can be a float, integer, or string.
from_base
Yes
It represents the base from which the number is converted.
to_base
Yes
It represents the base to which the number is converted.
Return Values
The return value is of the STRING type.
  • If the value of num, from_base, or to_base is NULL, NULL is returned.
  • The conversion process works with 64-bit precision and returns NULL when there is overflow.
  • If the value of num is a decimal, it will be converted to an integer before the base conversion, and the decimal part will be discarded.
Example Code
The value 8 is returned.
select conv('1000', 2, 10);
The value B is returned.
select conv('1011', 2, 16);
The value 703710 is returned.
select conv('ABCDE', 16, 10);
The value 27 is returned.
select conv(1000.123456, 3.123456, 10.123456);
The value 18446744073709551589 is returned.
select conv(-1000.123456, 3.123456, 10.123456);
The value NULL is returned.
select conv('1100', null, 10);
