ceil
This function is used to round up a to the nearest integer.
Syntax
ceil(DOUBLE a)
Parameters
| Parameter | Mandatory | Type | Description |
| a | Yes | DOUBLE, BIGINT, DECIMAL, or STRING | The value can be a float, integer, or string. If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation. |
Return Values
The return value is of the DECIMAL type.
If the value of a is NULL, NULL is returned.
Example Code
The value 2 is returned.
select ceil(1.3);
The value -1 is returned.
select ceil(-1.3);
The value NULL is returned.
select ceil(null);
