atan
This function is used to return the arc tangent value of a given angle a.
Syntax
atan(DOUBLE a)
Parameters
Parameter |
Mandatory |
Type |
Description |
a |
Yes |
DOUBLE, BIGINT, DECIMAL, or STRING |
The value can be a float, integer, or string. If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation. |
Return Values
The return value is of the DOUBLE type. The value ranges from -π/2 to π/2.
- If the value of a is not within the range [-1, 1], NaN is returned.
- If the value of a is NULL, NULL is returned.
Example Code
The value 0.7853981633974483 is returned.
select atan(1);
The value 0.5404195002705842 is returned.
select atan(0.6);
The value NULL is returned.
select atan(null);
