bin
This function is used to return the binary format of a.
Syntax
bin(BIGINT a)
Parameters
| Parameter | Mandatory | Type | Description |
| a | Yes | DOUBLE, BIGINT, DECIMAL, or STRING | The value is an integer. If the value is not of the BIGINT type, the system will implicitly convert it to the BIGINT type for calculation. |
Return Values
The return value is of the STRING type.
If the value of a is NULL, NULL is returned.
Example Code
The value 1 is returned.
select bin(1);
The value NULL is returned.
select bin(null);
The value 1000 is returned.
select bin(8);
select bin(8.123456);
