Concepts
  Sticky sessions ensure continuity and consistency when you access applications. If a load balancer is deployed between a client and backend servers, connections may be forwarded to different servers for processing. Sticky sessions can resolve this issue. After sticky session is enabled, requests from the same client will be continuously distributed to the same backend server through load balancing.
  For example, in most online systems that require user identity authentication, a user needs to interact with the server for multiple times to complete a session. These interactions require continuity. If sticky session is not configured, the load balancer may allocate certain requests to different backend servers. Since user identity has not been authenticated on other backend servers, interaction exceptions such as a user login failure may occur.
  Therefore, select a proper sticky session type based on the application environment.
     Table 1 Sticky session types
      | OSI Layer | Listener Protocol and Networking | Sticky Session Type | Scenarios Where Sticky Sessions Become Invalid |
      | Layer 4 | TCP- or UDP-compliant Services | Source IP address: The source IP address of each request is calculated using the consistent hashing algorithm to obtain a unique hashing key, and all backend servers are numbered. The system allocates the client to a particular server based on the generated key. This allows requests from the same IP address are forwarded to the same backend server. |
        Source IP addresses of the clients have changed.Requests from the clients exceed the session stickiness duration. |
      | Layer 7 | HTTP- or HTTPS-compliant ingresses |
        Load balancer cookie: The load balancer generates a cookie after receiving a request from the client. All subsequent requests with the cookie will be routed to the same backend server.Application cookie: The application deployed on the backend server generates a cookie after receiving the first request from the client. All subsequent requests with the same cookie will be routed to the same backend server. |
        If requests sent by the clients do not contain a cookie, sticky sessions will not take effect.Requests from the clients exceed the session stickiness duration. |
    When creating a load balancer, configure sticky sessions by setting kubernetes.io/elb.lb-algorithm to ROUND_ROBIN or kubernetes.io/elb.lb-algorithm to LEAST_CONNECTIONS. If you set kubernetes.io/elb.lb-algorithm is to SOURCE_IP, source IP address-based sticky sessions are supported. In this case, you do not need to configure sticky sessions again.
Enabling Layer 4 Sticky Session in a CCE Standard Cluster
     In a CCE standard cluster, to enable source IP address-based sticky session for a Service, ensure the following conditions are met:
      - Service Affinity of the Service must be set to Node-level, where the externalTrafficPolicy value of the Service must be Local.
- Anti-affinity has been enabled on the backend applications of the Service to prevent all pods from being deployed on the same node.
     - Create an Nginx workload.
       Set the number of pods to 3 and configure podAntiAffinity.
        kind: Deployment
apiVersion: apps/v1
  namespace: default
  replicas: 3
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      containers:
        - name: container-0
          image: 'nginx:perl'
          resources:
            limits:
              cpu: 250m
              memory: 512Mi
            requests:
              cpu: 250m
              memory: 512Mi
      imagePullSecrets:
        - name: default-secret
      affinity:
        podAntiAffinity:                   # Pod anti-affinity
          requiredDuringSchedulingIgnoredDuringExecution:
            - labelSelector:
                matchExpressions:
                  - key: app
                    operator: In
                    values:
                      - nginx
              topologyKey: kubernetes.io/hostname
- Create a LoadBalancer Service, for example, using an existing load balancer. The following shows an example YAML file for configuring source IP address-based sticky sessions:
      apiVersion: v1
kind: Service
  namespace: default
  annotations:
    kubernetes.io/elb.class: union
    kubernetes.io/elb.id: *****
    kubernetes.io/elb.lb-algorithm: ROUND_ROBIN      # Weighted round robin allocation policy
    kubernetes.io/elb.session-affinity-mode: SOURCE_IP    # Enable source IP address-based sticky session.
  selector:
    app: nginx
  externalTrafficPolicy: Local    # Node level Service affinity
  ports:
    - name: cce-service-0
      targetPort: 80
      nodePort: 32633
      port: 80
      protocol: TCP
  type: LoadBalancer
- Check whether the Layer 4 sticky session function is enabled.
       - Log in to the ELB console, locate the row containing the target load balancer, and click the listener name.
- Check whether the sticky session function is enabled in the backend server group.
Enabling Layer 4 Sticky Session in a CCE Turbo Cluster
    In a CCE Turbo cluster, enabling source IP address-based sticky session for a Service relies on the load balancer type.
     - When a dedicated load balancer is used, passthrough networking is allowed between the load balancer and pods, and pods function as the backend server group of the load balancer. Therefore, you do not need to configure Service affinity or application anti-affinity when enabling source IP address-based sticky session for the Service.
- If a shared load balancer is used, sticky session cannot be enabled.
     - For dedicated load balancers
       The following shows an example YAML file for configuring source IP address-based sticky sessions for a Service that uses an existing load balancer:
        apiVersion: v1
kind: Service
  namespace: default
  annotations:
    kubernetes.io/elb.class: performance
  selector:
    app: nginx
  externalTrafficPolicy: Cluster     # In CCE Turbo clusters, Service affinity does not need to be configured if a dedicated load balancer is used.
  ports:
      targetPort: 80
      nodePort: 32633
      port: 80
      protocol: TCP
  type: LoadBalancer
       Verify that the Layer 4 sticky session function is enabled.
Enabling Layer 7 Sticky Session in a CCE Standard Cluster
    To enable cookie-based sticky session on an ingress, ensure the following conditions are met:
     - Service Affinity of the ingress must be set to Node-level, where the externalTrafficPolicy value of the Service must be Local.
- Anti-affinity must be enabled for the ingress workload to prevent all pods from being deployed on the same node.
        kind: Deployment
apiVersion: apps/v1
  namespace: default
  replicas: 3
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      containers:
        - name: container-0
          image: 'nginx:perl'
          resources:
            limits:
              cpu: 250m
              memory: 512Mi
            requests:
              cpu: 250m
              memory: 512Mi
      imagePullSecrets:
      affinity:
            - labelSelector:
                matchExpressions:
                  - key: app
                    operator: In
                    values:
                      - nginx
- Create a Service for the workload. This section uses a NodePort Service as an example.
       Configure sticky sessions during the creation of a Service. An ingress can access multiple Services, and each Service can have different sticky sessions.
        apiVersion: v1
kind: Service
  namespace: default
  annotations:
    kubernetes.io/elb.session-affinity-mode: HTTP_COOKIE      # HTTP cookie
    kubernetes.io/elb.session-affinity-option: '{"persistence_timeout":"1440"}'   # Session stickiness duration, in minutes. The value ranges from 1 to 1440.
  selector:
    app: nginx
  ports:
      protocol: TCP
      port: 80
      targetPort: 80
      nodePort: 32633            # Custom node port
  type: NodePort
You can also select APP_COOKIE.
        Only shared load balancers support application cookie-based sticky sessions.
 apiVersion: v1
kind: Service
  namespace: default
  annotations:
    kubernetes.io/elb.session-affinity-mode: APP_COOKIE     # Select APP_COOKIE.
    kubernetes.io/elb.session-affinity-option: '{"app_cookie_name":"test"}'  # Application cookie name
  selector:
    app: nginx
  ports:
      protocol: TCP
      port: 80
      targetPort: 80
  type: NodePort
- Create an ingress and associate it with the Service.
kind: Ingress
  namespace: default
  annotations:
    kubernetes.io/elb.port: '80'
  rules:
  - host: 'www.example.com'
    http:
      paths:
      - path: '/'
        backend:
          service:
            name: nginx     # Service name
            port:
              number: 80
        property:
  ingressClassName: cce
- Verify that the Layer 7 sticky session function is enabled.
- Click the Forwarding Policies tab, click the backend server group name, and check whether sticky session is enabled for it.
Enabling Layer 7 Sticky Session in a CCE Turbo Cluster
    Enable cookie-based sticky session on the ingress.
     - When a dedicated load balancer is used, passthrough networking is allowed between the load balancer and pods, and pods function as the backend server group of the load balancer. Therefore, you do not need to configure Service affinity or application anti-affinity when enabling cookie-based sticky session for the ingress.
       - Create a Service for the workload. In a CCE Turbo cluster, the ingresses that use a dedicated load balancer must interconnect with ClusterIP Services.
          apiVersion: v1
kind: Service
  namespace: default
  annotations:
  selector:
    app: nginx
  ports:
      protocol: TCP
      port: 80
      targetPort: 80
      nodePort: 0
  type: ClusterIP
kind: Ingress
  namespace: default
  annotations:
  rules:
    http:
      paths:
      - path: '/'
        backend:
          service:
            port:
              number: 80
        property:
