Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ Nodes/ Node O&M/ Migrating Nodes from Docker to containerd
As of Kubernetes v1.24, dockershim has been deprecated. To maintain compatibility and ensure continued support for future Kubernetes releases, switch your node's container runtime from Docker to the officially endorsed containerd.
  • At least one cluster that supports containerd nodes has been created.
  • There is a Docker node or Docker node pool in your cluster.
Precautions
  • Theoretically, migration during container running will interrupt services for a short period of time. Therefore, it is strongly recommended that the services to be migrated have been deployed as multi-instance. In addition, you are advised to test the migration impact in the test environment to minimize potential risks.
  • containerd cannot build images. Do not use the docker build command to build images on containerd nodes. For other differences between Docker and containerd, see Container Engines.
Procedure for Migrating Nodes in the Default Node Pool
  2. In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab.
  3. In the node list, select one or more nodes to be reset and choose More > Reset Node in the Operation column.
  4. Set Container Engine to containerd. You can adjust other parameters as required or retain them as set during creation.
  5. If the node status is Installing, the node is being reset.
    When the node status is Running, you can see that the node version is switched to containerd. You can log in to the node and run containerd commands such as crictl to view information about the containers running on the node.
Procedure for Migrating Nodes in a Custom Node Pool
You can copy a node pool, set the container engine of the new node pool to containerd, and keep other configurations the same as those of the original Docker node pool.
  2. In the navigation pane, choose Nodes. On the Node Pools tab page, locate the Docker node pool to be copied and choose More > Copy in the Operation column.
  3. In the Configurations area, set Container Engine to containerd and modify other parameter settings as needed to create the node pool.
  4. Scale the number of created containerd node pools to the number of original Docker node pools and delete nodes from the Docker node pools one by one.
    Rolling migration is preferred. That is, add some containerd nodes and then delete some Docker nodes until the number of nodes in the new containerd node pool is the same as that in the original Docker node pool.
    If you have configured node affinity for the workloads deployed on the original Docker nodes or node pool, configure affinity policies for the workloads to run on the new containerd nodes or node pool.
  5. After the migration, delete the original Docker node pool.
