Configuring Labels and Annotations
Pod Annotations
CCE allows you to add annotations to a YAML file to realize some advanced pod functions. The following table describes the annotations you can add.
Table 1 Pod annotations
Annotation
Default Value
kubernetes.AOM.log.stdout
Standard output parameter. If not specified, the standard log output of all containers is reported to AOM. You can collect stdout logs from certain containers or ignore them at all.
Example:
  • Collecting none of the stdout logs:
    kubernetes.AOM.log.stdout: '[]'
  • Collecting stdout logs of container-1 and container-2:
    kubernetes.AOM.log.stdout: '["container-1","container-2"]'
None
metrics.alpha.kubernetes.io/custom-endpoints
Parameter for reporting AOM monitoring metrics that you specify.
For details, see Monitoring Custom Metrics on AOM.
None
prometheus.io/scrape
Parameter for reporting Prometheus metrics. If the value is true, the current workload reports the monitoring metrics.
None
prometheus.io/path
URL for Prometheus to collect data.
/metrics
prometheus.io/port
Endpoint port number for Prometheus to collect data.
None
prometheus.io/scheme
Protocol used by Prometheus to collect data. The value can be http or https.
None
kubernetes.io/ingress-bandwidth
Ingress bandwidth of a pod.
For details, see Configuring QoS for a Pod.
None
kubernetes.io/egress-bandwidth
Egress bandwidth of a pod.
None
Pod Labels
When you create a workload on the console, the following labels are added to the pod by default. The value of app is the workload name.
Example YAML:
  selector:
    matchLabels:
      app: nginx
      version: v1
  template:
      labels:
        app: nginx
        version: v1
You can also add other labels to the pod for affinity and anti-affinity scheduling. In the following figure, three pod labels (release, env, and role) are defined for workload APP 1, APP 2, and APP 3. The values of these labels vary with workload.
  • APP 1: [release:alpha;env:development;role:frontend]
  • APP 2: [release:beta;env:testing;role:frontend]
  • APP 3: [release:alpha;env:production;role:backend]
Figure 1 Label example
For example, if key/value is set to role/backend, APP 3 will be selected for affinity scheduling. For details, see Workload Affinity (podAffinity).
