Configuring QoS for a Pod
Bandwidth preemption occurs between different containers deployed on the same node, which may cause service jitter. You can configure QoS rate limiting for inter-pod access to prevent this problem.
Notes and Constraints
Constraint Type |
Tunnel network model |
VPC network model |
Cloud Native 2.0 Network Model |
Supported versions |
All versions |
Clusters of v1.19.10 and later |
Supported runtime types |
Only common containers |
Supported pod types |
Only non-HostNetwork pods |
Supported scenarios |
Inter-pod access, pods accessing nodes, and pods accessing services |
Constraints |
None |
None |
Value range of rate limit |
Only the rate limit in the unit of Mbit/s or Gbit/s is supported, for example, 100 Mbit/s and 1 Gbit/s. The minimum value is 1 Mbit/s and the maximum value is 4.29 Gbit/s. |
Using the CCE Console
When creating a workload on the console, you can set pod ingress and egress bandwidth limits by clicking Network Configuration in the Advanced Settings area.
Using kubectl
apiVersion: apps/v1 kind: Deployment metadata: name: test namespace: default labels: app: test spec: replicas: 2 selector: matchLabels: app: test template: metadata: labels: app: test annotations: kubernetes.io/ingress-bandwidth: 100M kubernetes.io/egress-bandwidth: 100M spec: containers: - name: container-1 image: nginx:alpine imagePullPolicy: IfNotPresent imagePullSecrets: - name: default-secret
- kubernetes.io/ingress-bandwidth: ingress bandwidth of the pod
- kubernetes.io/egress-bandwidth: egress bandwidth of the pod
If these two parameters are not specified, the bandwidth is not limited.
After modifying the ingress or egress bandwidth limit of a pod, restart the container for the modification to take effect. After annotations are modified in a pod not managed by workloads, the container will not be restarted, so the bandwidth limits do not take effect. You can create a pod again or manually restart the container.
