On this page
Show all
Error Codes
The following table lists the error codes that you may encounter when calling APIs. If an error code starting with APIGW is returned after you call an API, rectify the fault by referring to the instructions provided in section "Error Codes" in the API Request Signing Guide.
  • For details about the error codes that may occur when you manage APIs, see section "Error Codes" in the API Gateway API Reference.
  • If an error occurs when you use APIG, find the error message and description in the following table according to the error code, for example, APIG.0101. The error messages are subject to change without prior notice.
Table 1 Error codes
Error Code
Error Message
HTTP Status Code
Solution
APIG.0101
The API does not exist or has not been published in the environment.
404
Check whether the domain name, method, and path are consistent with those of the created API. Check whether the API has been published. If it has been published in a non-production environment, check whether the X-Stage header in the request is the environment name. Check whether the domain name used to call the API has been bound to the group to which the API belongs.
APIG.0101
The API does not exist.
404
The API request method does not exist.
Check whether the API request method is the same as the method defined by the API.
APIG.0103
The backend does not exist.
500
The backend service was not found.
Contact technical support.
APIG.0104
The plug-ins do not exist.
500
No plug-in configurations were found.
APIG.0105
The backend configurations do not exist.
500
No backend configurations were found.
APIG.0106
Orchestration error.
400
An orchestration error occurred.
Check whether the frontend and backend parameters of the API are correct.
APIG.0107
The custom lua script encountered an unexpected error
500
An unknown error occurred in the Lua script.
APIG.0201
API request error.
400
Invalid request parameters.
Set valid request parameters.
APIG.0201
Request entity too large.
413
The request body exceeds 12 MB.
Reduce the size of the request body.
APIG.0201
Request URI too large.
414
The request URI exceeds 32 KB.
Reduce the size of the request URI.
APIG.0201
Request headers too large.
494
The request headers are too large because one of them exceeds 32 KB or the total length exceeds 128 KB.
Reduce the size of the request headers.
APIG.0201
Backend unavailable.
502
The backend service is unavailable.
Check whether the backend address configured for the API is accessible.
APIG.0201
Backend timeout.
504
The backend service has timed out.
Increase the timeout duration of the backend service or shorten the processing time.
APIG.0201
An unexpected error occurred
500
An internal error occurred.
APIG.0202
Backend unavailable
502
The backend is unavailable.
Check whether the backend request protocol configured for the API is the same as the request protocol used by the backend service.
APIG.0203
Backend timeout
504
APIG.0204
SSL protocol is not supported: TLSv1.1
400
The SSL protocol version is not supported.
Use a supported SSL protocol version.
APIG.0205
Verify client certificate failed
400
Failed to verify the client certificate.
Check whether the client certificate is correct.
APIG.0301
Incorrect IAM authentication information.
401
The IAM authentication details are incorrect.
Check whether the token is correct.
APIG.0302
The IAM user is not authorized to access the API.
403
The IAM user is not allowed to access the API.
Check whether the user is controlled by a blacklist or whitelist.
APIG.0303
Incorrect app authentication information.
401
The app authentication details are incorrect.
Check whether the request method, path, query strings, and request body are consistent with those used for signing; check whether the date and time on the client are correct; and check whether the signing code is correct by referring to section "Calling APIs Through App Authentication" of the Developer Guide.
APIG.0304
The app is not authorized to access the API.
403
The app is not allowed to access the API.
Check whether the app has been authorized to access the API.
APIG.0305
Incorrect authentication information.
401
The authentication information is incorrect.
Check whether the authentication information is correct.
APIG.0306
API access denied.
403
Access to the API is not allowed.
Check whether you have been authorized to access the API.
APIG.0307
The token must be updated.
401
The token needs to be updated.
Obtain a new token from IAM.
APIG.0308
The throttling threshold has been reached.
429
Try again after the throttling resumes. If the number of debugging domain requests per day is reached, bind an independent domain name to the service to which the API belongs.
APIG.0310
The project is unavailable.
403
The project is currently unavailable.
Select another project and try again.
APIG.0311
Incorrect debugging authentication information.
401
The debugging authentication details are incorrect.
APIG.0312
Incorrect third-party authentication information,auth fail
401
The authentication failed because the third-party authentication information is incorrect.
Check whether the identity information is correct.
APIG.0313
Incorrect third-party authentication information,identities error
401
The identity included in the third-party authentication information is incorrect.
Check whether the identity information is consistent with the identity source in the third-party authentication plug-in.
APIG.0314
Incorrect third-party authentication information,access deny
403
Access denied because the third-party authentication information is incorrect.
Contact technical support to check whether the request is a service request. If yes, increase the brute force threshold of the third-party authentication plug-in.
APIG.0401
Unknown client IP address.
403
The client IP address cannot be identified.
APIG.0402
The IP address is not authorized to access the API.
403
The IP address is not allowed to access the API.
Check whether the IP address is controlled by a blacklist or whitelist.
APIG.0404
Access to the backend IP address has been denied.
403
The backend IP address cannot be accessed.
Check whether the backend IP address or the IP address corresponding to the backend domain name is accessible.
APIG.0405
The app is not accessed from a trusted IP address.
403
The application is not accessed from a trusted IP address.
Check whether the source IP address is allowed or denied in the access control policy.
APIG.0501
The app quota has been used up.
405
The app quota has been reached.
Increase the app quota.
APIG.0502
The app has been frozen.
405
Check whether your account balance is sufficient.
APIG.0601
Internal server error.
500
APIG.0602
Bad request.
400
Invalid request.
Check whether the request is valid.
APIG.0605
Domain name resolution failed.
500
Check whether the domain name is correct and has been bound to a correct backend address.
APIG.0606
Failed to load the API configurations.
500
API configurations could not be loaded.
APIG.0607
The following protocol is supported: {xxx}
400
The protocol is not supported. Only xxx is supported.
xxx is subject to the actual value in the response.
Use HTTP or HTTPS to access the API.
APIG.0608
Failed to obtain the admin token.
500
The administrator account details cannot be obtained.
APIG.0609
The VPC backend does not exist.
500
The workload backend service cannot be found.
APIG.0610
No backend available.
502
No backend services are available.
Check whether all backend services are available. For example, check whether the API calling information is consistent with the actual configuration.
APIG.0611
The backend port does not exist.
500
The backend port was not found.
APIG.0612
An API cannot call itself.
500
Modify the backend configurations, and ensure that the number of layers the API is recursively called does not exceed 10.
APIG.0613
The IAM service is currently unavailable.
503
IAM is currently unavailable.
APIG.0615
Incorrect third-party authentication VPC information
500
Failed to obtain the load balance channel nodes for third-party authentication.
Check whether the load balance channel for third-party authentication is correctly configured.
APIG.0616
Incorrect third-party authentication request information
500
Failed to connect to the third-party authentication service.
Check whether the third-party authentication service is normal.
APIG.0617
Incorrect third-party authentication response information
500
Failed to obtain response from the third-party authentication service.
APIG.0705
Backend signature calculation failed.
500
APIG.0802
The IAM user is forbidden in the currently selected region
403
The IAM user is disabled in the current region.
APIG.2102
PublicKey is null
400
The signature key is not found.
APIG.2201
Appkey or SecretKey is invalid
400
Invalid AppKey or SecretKey.
Check whether the AppKey and SecretKey in the request are correct.
APIG.2202
Refresh token is invalid
400
Invalid refresh token.
Check whether the refresh token is correct.
APIG.2203
Access token is invalid
400
Invalid access token.
Check whether the access token is correct.
APIG.2204
ContentType invalid
400
Invalid ContentType.
Check whether the ContentType is correct.
APIG.2205
Auth parameter invalid
400
Invalid authentication parameter.
Check whether the authentication parameters are correct.
APIG.2206
Auth method invalid
400
Invalid authentication mode.
Check whether the authentication mode is correct.
APIG.2208
The length of through_data is out of range
400
The length of through_data is out of range.
The maximum length of through_data is 300. Adjust through_data based on the actual situation.
APIG.2209
The value of grant_type is not in enum List
400
The value of grant_type is invalid.
The value of grant_type can only be client_credentials or refresh_token. Change it based on the actual situation.
APIG.2210
Lack of grant_type
400
The authorization type is missing.
Add grant_type.
APIG.2211
Lack of client_id
400
The client ID is missing.
Add a client ID.
APIG.2212
Lack of client_secret
400
The client secret is missing.
Add a client secret.
APIG.2213
Lack of refresh_token
400
The refresh token is missing.
APIG.1001
Refresh token is expired
401
The refresh token has expired.
Obtain another refresh token.
APIG.1002
Access token is expired
401
The access token has expired.
Obtain another access token.
APIG.1003
App not match refresh token
401
The app does not match the refresh token.
Check whether the client_id is correct.
APIG.1004
App not exist
401
The app does not exist.
APIG.1009
AppKey or AppSecret is invalid
400
The AppKey or AppSecret is invalid.
Check whether the AppKey or AppSecret in the request is correct.
