Creating an API
Procedure:
  1. Configuring Frontend Settings
  2. Configuring Backend Settings
  1. In the navigation pane, choose API Management > APIs.
  2. Click Create API > Create API and configure the frontend.
    Table 1 Frontend definition
    Name
    API name. It is recommended that you enter a name based on naming rules to facilitate search.
    Group
    By default, the group created in Creating an API Group is selected.
    URL
    Method: Request method of the API. Set this parameter to POST.
    Protocol: Set this parameter to HTTPS.
    Subdomain name: The subdomain automatically allocated to the API group created in Creating an API Group.
    Path: Path for requesting the API.
    Gateway Response
    Select a response to be displayed if API Gateway fails to process an API request.
    The default gateway response is default.
    Matching
    By default, Exact match is selected.
    Tags
    Classification attribute used to quickly identify the API from other APIs.
    Description of the API.
  3. Configure security settings based on the following table.
    Table 2 API request definition
    Authentication Mode
    API authentication mode. Set this parameter to App.
    Simple Authentication
    If you enable this option, API Gateway verifies only the AppCode and the request signature does not need to be verified. For this example, enable simple authentication.
  4. Click Next.
  1. On the Backend Configuration page, set the backend service information.
  2. Select a backend service type. For this example, select HTTP&HTTPS.
    Table 3 HTTP&HTTPS backend service definition
    Load Balance Channel
    Determine whether the backend service will be accessed using a load balance channel. For this example, select Skip.
    URL
    Protocol: Set this parameter to HTTP.
    Backend Address: Address of the backend service.
    Path: Path of the backend service.
    Timeout
    Backend service request timeout. Default value: 5000 ms.
  3. On the Define Response page, set the responses.
    Table 4 Defining responses
    Example Success Response
    An example of a response returned when the API is called successfully.
    Example Failure Response
    An example of a response returned when the API fails to be called.
  4. Click Finish.
