Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Resource O&M/
Batch Operations on BMSs/
Batch Restarting BMSs
Restart BMS instances in batches on COC.
Precautions
Stopped instances cannot be selected.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Resource Batch Operations. On the displayed page, click the Bare Metal Server (BMS) tab, and then click the Restart BMSs card on the tab page.
- On the Restart BMSs page, click Add.
Figure 1 Selecting instances
- Select Batch Policy.
- Automatic: The selected hosts are automatically divided into multiple batches based on the preset rule.
- Manual: You can manually create multiple batches and add instances to each batch as required.
- No batch: All target instances are in the same batch.
- Set Suspension Policy.
- You can set the execution success rate. When the number of failed instances reaches the number failed ones that are calculated based on the execution success rate, the service ticket status becomes abnormal and the service ticket stops being executed.
- The value is from 0 to 100 and can be accurate to one decimal place.
- Click Submit.
Figure 2 Restarting instances
- In the Confirm Execution dialog box, click OK.
Figure 3 Confirming the execution
- View the execution result.
Figure 4 Viewing the result
- If the execution result is abnormal, you can click the Retry button in the Operation column or the Batch Retry button above the list to re-execute the failed one or more tasks. You can also click the Cancel button in the Operation column or Batch Cancel button above the list to skip one or more abnormal tasks.
Figure 5 Canceling or retrying a batch BMS startup task
Parent topic: Batch Operations on BMSs
