Updated on 2025-01-09 GMT+08:00
DELETE
Function
This command deletes records from a Delta table.
Syntax
DELETE from[database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
[ WHERE boolExpression]
Parameter Description
Table 1 Parameter descriptions of DELETE
database_name
Name of the database, consisting of letters, numbers, and underscores (_)
table_name
Name of the table in the database, consisting of letters, numbers, and underscores (_)
bucket_name
OBS bucket name
tbl_path
Storage location of the Delta table in the OBS bucket
boolExpression
Filter conditions for deleting records
Required Permissions
  • SQL permissions
Table 2 Permissions required for executing DELETE
Permission Description
DELETE permission on a table
  • Fine-grained permission: dli:table:delete
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
delete from delta_table0 where column1 = 'value1';
delete from delta_table0 where column1 IN ('value1', 'value2');
delete from delta.`obs://bucket_name0/db0/delta_table0` where column1 = 'value1';
System Response
You can view the result in driver logs or on the client.
