Updated on 2026-08-14 GMT+08:00
Streaming Output
Streaming output refers to the process in which a large model immediately pushes each generated segment to the caller as it is produced, rather than waiting until the entire response is complete. It reduces the time to first token (TTFT), allowing users to see responses sooner and experience smoother interactions.
The process works as follows:
  1. The caller initiates a request with the stream field set to True, enabling the streaming mode.
  2. The model generates the response token by token.
  3. Each segment is immediately pushed to the caller via Server-Sent Events (SSE) or other methods.
  4. Once all content has been generated, an end-flag signal is sent.
Application Scenarios
  • Intelligent conversation: Responses are displayed word by word, allowing users to read content immediately without waiting for the full reply, creating a more natural and seamless experience.
  • Long-text generation: Articles and reports are generated and streamed simultaneously, reducing perceived waiting time.
  • Code completion: Code suggestions are provided line by line, allowing developers to view and decide whether to accept them in real time.
  • Real-time translation: Translations are returned segment by segment as source text is entered, suitable for scenarios like simultaneous interpretation during meetings.
  • Content summarization: Summaries of long documents are delivered step by step, helping users quickly assess relevance.
  • Data report interpretation: Large-scale analysis results are streamed in segments, making complex data easier to understand.
Billing
The billing rules for streaming output are the same as those for non-streaming output. Both are charged based on the number of tokens consumed in the input and output. In streaming output scenarios, if a request is interrupted, only the tokens that have been successfully generated are billed, and the tokens that have not been generated are not billed.
API Description
For the complete parameters for model calls, see Sending a Chat Request (Chat/Post).
  • You have subscribed to the built-in service on the Model Inference > Real-Time Inference > Built-in Services tab page. For details, see Subscribing to a Built-in Service.
  • (Optional) To control the service call traffic, you can create a custom endpoint in advance. For details, see Creating an Endpoint.
Getting Started
The following uses the GLM-5.2 model as an example to demonstrate the streaming output in non-thinking mode.
In thinking mode, the thinking process is also output in streaming mode. In the thinking phase, the reasoning_content field contains the content that the model is thinking about, and the content field is empty. After the thinking is complete, the content field is populated with a value.
import requests
import json
if __name__ == '__main__':
    url = "https://api-ap-southeast-1.modelarts-maas.com/v2/chat/completions"  # API URL
    api_key = "MAAS_API_KEY"  # Replace MAAS_API_KEY with the obtained API key.
    # Send request.
    headers = {
        'Content-Type': 'application/json',
        'Authorization': f'Bearer {api_key}'
    data = {
        "model": "glm-5.2", # Model
         "messages": [
             {"role": "system", "content": "You are a helpful assistant."},
            {"role": "user", "content": "Hello"}
        "thinking": {
            "type": "disabled"
         "stream": True
    response = requests.post(url, headers=headers, data=json.dumps(data), verify=False)
    # Print result.
    print(response.status_code)
    print(response.text)
curl -X POST "https://api-ap-southeast-1.modelarts-maas.com/v2/chat/completions" \
-H "Content-Type: application/json" \
-H "Authorization: Bearer $MAAS_API_KEY" \
-d '{
    "model": "glm-5.2",
    "messages": [
    "thinking": {
        "type": "disabled"
    "stream": true
from openai import OpenAI
import httpx
base_url = "https://api-ap-southeast-1.modelarts-maas.com/openai/v1"  # API address
client = OpenAI(api_key=api_key, base_url=base_url, http_client=httpx.Client(verify=False))
response = client.chat.completions.create(
    model="glm-5.2",
    messages=[
        {"role": "system", "content": "You are a helpful assistant"},
        {"role": "user", "content": "Hello"},
    chat_template_kwargs = {
        "thinking": False
    stream=True
for chunk in response:
    if not chunk.choices:
        continue
    print(chunk.choices[0].delta.content, end="")
Streaming output:
data: {"id":"4dc9cd5407fa4fcf92e5d547984819fd","object":"chat.completion.chunk","created":1784770930,"model":"glm-5.2","choices":[{"index":0,"delta":{"role":"assistant","content":"Hello"}}],"service_tier":"default","first_token_return_time":1784770931.0727186}
data: {"id":"4dc9cd5407fa4fcf92e5d547984819fd","object":"chat.completion.chunk","created":1784770930,"model":"glm-5.2","choices":[{"index":0,"delta":{"role":"assistant","content":"Is there anything"}}],"service_tier":"default","first_token_return_time":1784770931.0729105}
data: {"id":"4dc9cd5407fa4fcf92e5d547984819fd","object":"chat.completion.chunk","created":1784770930,"model":"glm-5.2","choices":[{"index":0,"delta":{"role":"assistant","content":"I can help you with"}}],"service_tier":"default","first_token_return_time":1784770931.1312485}
data: {"id":"4dc9cd5407fa4fcf92e5d547984819fd","object":"chat.completion.chunk","created":1784770930,"model":"glm-5.2","choices":[{"index":0,"delta":{"role":"assistant","content":"?"}}],"service_tier":"default","first_token_return_time":1784770931.1887114}
data: {"id":"4dc9cd5407fa4fcf92e5d547984819fd","object":"chat.completion.chunk","created":1784770930,"model":"glm-5.2","choices":[{"index":0,"delta":{"role":"assistant","content":""},"finish_reason":"stop"}],"service_tier":"default","first_token_return_time":1784770931.1887114}
data: {"id":"4dc9cd5407fa4fcf92e5d547984819fd","object":"chat.completion.chunk","created":1784770930,"model":"glm-5.2","choices":[],"usage":{"prompt_tokens":14,"total_tokens":23,"completion_tokens":9,"prompt_tokens_details":{"cached_tokens":0},"completion_tokens_details":{"reasoning_tokens":0}},"service_tier":"default","first_token_return_time":1784770931.188748}
data: [DONE]
Error Codes
If an error is reported during model calling, rectify the fault by referring to Error Codes.
