Deep Thinking
When handling complex tasks, traditional models often struggle to provide comprehensive and insightful responses. To address this, you can use advanced models capable of deep thinking. These models analyze and break down questions before providing answers, resulting in more thorough and detailed responses. When you query the model, MaaS returns the logical thought process (chain-of-thought content) used by the model before answering the question. This allows you to observe the model's reasoning process and utilize this information. By enabling models with deep thinking capabilities, you can significantly enhance the quality and depth of responses. Additionally, reviewing the chain-of-thought content helps you better understand the model's reasoning process.
How It Works
In addition to generating questions and answers, deep-thinking models also produce Chain-of-Thought (CoT) reasoning traces. CoT refers to the model's ability to generate a series of intermediate reasoning steps when solving complex problems. This capability allows the model not only to provide the final answer but also to demonstrate its reasoning process, thereby enhancing the model's explainability and transparency.
Supported Models
For the models currently supported for deep thinking, see Deep Thinking.
API Description
For the complete parameters for model calls, see Sending a Chat Request (Chat/Post).
- You have subscribed to the built-in service on the Model Inference > Real-Time Inference > Built-in Services tab page. For details, see Subscribing to a Built-in Service.
- (Optional) To control the service call traffic, you can create a custom endpoint in advance. For details, see Creating an Endpoint.
- The API key has been obtained. For details, see Managing API Keys in MaaS.
- The model parameter value for the model service has been obtained. For details about the supported models and APIs, see Sending a Chat Request (Chat/Post).
Chain of Thought Usage Guide
| Model | CoT Switch Parameter Format | Parameter | Default Configuration |
| GLM-5.1 GLM-5.2 | "thinking": { "type": "enabled" } |
| CoT enabled |
| DeepSeek-V4-Flash DeepSeek-V4-Pro | "thinking": { "type": "enabled" } |
| CoT enabled |
Getting Started
Run the following code to quickly call DeepSeek-V4-Flash with deep thinking enabled via streaming output.
import requests
import json
if __name__ == '__main__':
url = "https://api-ap-southeast-1.modelarts-maas.com/v2/chat/completions" # API URL
api_key = "MAAS_API_KEY" # Replace MAAS_API_KEY with the obtained API key.
# Send request.
headers = {
'Content-Type': 'application/json',
'Authorization': f'Bearer {api_key}'
data = {
"model": "deepseek-v4-flash", # model parameter. The following uses deepseek-v4-flash as an example. You can change the model parameter as needed. For details, see Deep Thinking.
"messages": [
{"role": "system", "content": "You are a helpful assistant."},
{"role": "user", "content": "Hello"}
"thinking": {
"type": "enabled" # Enable deep thinking mode
response = requests.post(url, headers=headers, data=json.dumps(data), verify=False)
# Print result.
print(response.status_code)
print(response.text) curl -X POST "https://api-ap-southeast-1.modelarts-maas.com/v2/chat/completions" \
-H "Content-Type: application/json" \
-H "Authorization: Bearer $MAAS_API_KEY" \
-d '{
"messages": [
"thinking": {
"type": "enabled"
}' JDK later than 15 is recommended.
import java.net.URI;
import java.net.http.HttpClient;
import java.net.http.HttpRequest;
import java.net.http.HttpResponse;
import java.time.Duration;
public class ChatCompletionsExample {
// API URI
String apiUrl = "https://api-ap-southeast-1.modelarts-maas.com/v2/chat/completions" ;
// Replace MAAS_API_KEY with the obtained API key.
String apiKey = "MAAS_API_KEY";
// Replace it with the model you want to call, for example, "deepseek-v4-flash".
String modelName = "deepseek-v4-flash";
// Construct a request body.
String requestBody = String.format(
"model": "%s",
"messages": [
"thinking": {
"type": "enabled"
}""", modelName);
// Create an HttpClient.
HttpClient client = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(10))
.build();
// Create a request.
HttpRequest request = HttpRequest.newBuilder()
.uri(URI.create(apiUrl))
.header("Content-Type", "application/json")
.header("Authorization", "Bearer " + apiKey)
.POST(HttpRequest.BodyPublishers.ofString(requestBody))
.build();
try {
// Send the request and print the result.
HttpResponse<String> response = client.send(
request, HttpResponse.BodyHandlers.ofString());
System.out.println("HTTP Status: " + response.statusCode());
System.out.println("Response Body:\n" + response.body());
} catch (Exception e) {
e.printStackTrace();
} Multi-Turn Dialogue
Combining system messages, model messages, and user messages enables multi-turn conversations. To maintain context within a specific topic, you can input historical conversation records to the model.
The following is an example code for a multi-turn conversation with deep thinking enabled. You can replace the model by modifying the model parameter. For details about the model parameter, see Text Generation.
reasoning_content is an output field of the model and should not be used as input. If this field is included in the messages sequence, it will be ignored and not used as model input. During multi-turn conversations, only the role and content fields should be retained. Refer to the example below. For more details, see Sending a Chat Request (Chat/Post).
import requests
import json
# Send request.
headers = {
data = {
"model": "deepseek-v4-flash",# The following uses deepseek-v4-flash as an example. You can change the model parameter as needed. For details, see Deep Thinking.
"messages": [
{"role": "user", "content": "Hello"},
{"role": "assistant", "content": "Hello! Nice to meet you!"},
{"role": "user", "content": "Introduce yourself."}
"thinking": {
# Print result.
-d '{
"messages": [
"thinking": {
"type": "enabled"
}' from openai import OpenAI import httpx base_url = "https://api-ap-southeast-1.modelarts-maas.com/openai/v1" # API address api_key = "MAAS_API_KEY" # Replace MAAS_API_KEY with the obtained API key. client = OpenAI(api_key=api_key, base_url=base_url, http_client=httpx.Client(verify=False)) response = client.chat.completions.create( model="deepseek-v4-flash", # The following uses deepseek-v4-flash as an example. You can change the model parameter as needed. For details, see Deep Thinking. messages=[ {"role": "user", "content": "Hello"}, {"role": "assistant", "content": "Hello! Nice to meet you!"}, {"role": "user", "content": "Introduce yourself."} ], chat_template_kwargs={"thinking": True} ) print(response.choices[0].message.content)
// API URI
String apiUrl = "https://api-ap-southeast-1.modelarts-maas.com/v2/chat/completions";
"model": "%s",
"messages": [
"thinking": {
"type": "enabled"
}""", modelName);
.build();
.build();
try {
} Streaming Output
With the LLM output, dynamic content is displayed as it is generated. This allows you to see partial results right away, making the wait feel shorter and improving your experience.
The following is an example code for streaming output with deep thinking enabled. You can replace the model by modifying the model parameter. For details about the model parameter, see Text Generation.
-d '{
"messages": [
"thinking": {
"type": "enabled"
"stream": true
}' from openai import OpenAI import httpx base_url = "https://api-ap-southeast-1.modelarts-maas.com/v2/chat/completions" # API address api_key = "MAAS_API_KEY" # Replace MAAS_API_KEY with the obtained API key. client = OpenAI(api_key=api_key, base_url=base_url, http_client=httpx.Client(verify=False)) response = client.chat.completions.create( model="deepseek-v4-flash", # The following uses deepseek-v4-flash as an example. You can change the model parameter as needed. For details, see Deep Thinking. messages=[ {"role": "system", "content": "You are a helpful assistant"}, {"role": "user", "content": "Hello"} ], stream = True, extra_body={ "thinking": { "type": "enabled" # Enable deep thinking mode } } ) for chunk in response: if not chunk.choices: continue print(chunk.choices[0].delta.content, end="")
public class ChatCompletionsExample3 {
// API URI
"model": "%s",
"messages": [
"thinking": {
"type": "enabled"
"stream": true
}""", modelName);
.build();
.build();
try {
} Enabling/Disabling Deep Thinking
For details about the models that support enabling or disabling chain-of-thought and the usage instructions, see Chain of Thought Usage Guide.
The following example code demonstrates how to disable deep thinking by replacing the model parameter. For details about the model parameter, see Text Generation. For details about the CoT switch, see Table 1.
import requests
import json
# Send request.
headers = {
data = {
"model": "qwen3-32b", # The following uses qwen3-32b as an example. You can change the model parameter as needed. For details, see Deep Thinking.
"messages": [
"thinking": {
"type": "enabled" # Specifies whether to enable deep thinking. It is enabled by default.
# Print result.
-d '{
"messages": [
"thinking": {
"type": "enabled"
// API URI
// Replace it with the model you want to call, for example, "qwen3-32b".
String modelName = "qwen3-32b";
// Construct a request body (compatible with OpenAI).
"model": "%s",
"messages": [
"thinking": {
"type": "enabled"
}""", modelName);
.build();
.build();
try {
} What is your overall rating for this page?
