Help Center/ MaaS/ Model Calling/ Appendix/ Subscribing to Built-in Services
Updated on 2026-08-14 GMT+08:00
MaaS offers built-in services that give businesses high-performance, reliable inference APIs. Billing is based on token usage. Commercial services fit situations needing high stability, frequent calls, and expert support.
  • Enterprise intelligent customer service: Enterprises hope to optimize their customer service systems by using inference APIs to achieve intelligent Q&A and intent recognition, thereby improving customer service efficiency and customer satisfaction.
  • Content creation assistance: Media and advertising companies leverage inference APIs for copywriting and creative generation, enhancing the efficiency and quality of content production.
  • Intelligent data analysis: Financial and e-commerce enterprises use inference APIs to conduct in-depth analysis of massive amounts of data, uncovering data value and aiding in decision-making.
  • This function is available only in the CN-Hong Kong region.
  • Subscribing to a built-in service will subscribe all versions of the service. You cannot subscribe to just one version alone.
  • Currently, built-in services cannot be disabled.
Billing
Model inference services process input by converting it into identifiable tokens. Using a built-in MaaS service charges you based on token count. For details, see Billing Items for Model Inference.
Coupon Instructions
  • When there is a discount offer, a relevant prompt will appear on the built-in service page. When subscribing to a built-in service, available coupons will be claimed by default. During the billing process, coupons will be applied first.
  • The scope of application and eligibility criteria for different coupon activities vary. Whether you can successfully claim a coupon depends on the actual activity rules.
  • For information on the issuance and usage of discount coupons for model services, go to Billing Center > Promotions > Coupons.
Service Calls
The platform can send requests to different regions as needed.
  1. Log in to the MaaS console and select the target region on the top navigation bar.
  2. In the navigation pane on the left, choose Model Inference > Real-time inference.
  3. Click the Built-in Services tab. In the Operation column of the target service, click Subscribe.
  4. Select the built-in service as required. Carefully read and agree to the terms, and then click Subscribe. The service's status in the built-in service list will change to Subscribed.
    Selecting a built-in service will subscribe all model versions of the service.
    The table below describes built-in service parameters.
    Table 1 Built-in service list parameters
    Name/Resource ID
    Name and ID of the built-in service.
    • Click on the left of the service name to view the service version. The name displayed in the model Parameter column can be used for model calls.
      Figure 1 Viewing the model version
      Click the version name to go to the Model Description page and view details about the model version.
    • Viewing the service bill: Click after the built-in service ID to copy the ID. On the Billing > Expenditure Details page of the Billing Center, view the bill details by resource ID.
    Status
    • Subscribed: The built-in service is enabled.
    • Not Subscribed: The built-in service is not enabled.
    Type
    Type of the built-in service
    Billing Mode
    Billing mode of the built-in service. The billing mode varies depending on the model. For details, see Billing Items.
    Infer Price
    Inference pricing of the built-in service. The inference pricing varies depending on the model. For details, see Billing Items.
    In the upper right corner of the page, enable or disable Million tokens unit display.
    Figure 2 Million tokens unit display
    • If Million tokens unit display is disabled, the price is displayed by thousand tokens.
    • If Million tokens unit display is enabled, the price is displayed by million tokens.
    Discounts
    Discounts available for the built-in service. -- indicates that there is no discount.
    Model flow limiting
    Total quota for accessing all services under the same model within the current account.
    • TPM: The number of tokens processed per minute, including both input and output.
    • RPM: The number of requests processed per minute.
    Call Statistics
    Click to go to the Service Call Details page and view the call data and monitoring metric details of the built-in service in a specified period. For more information, see Viewing the Call Data and Monitoring Metrics of Real-Time Inference on MaaS.
    Operation
    Operations supported by the built-in service
    • Unsubscribe: If this button is unavailable, the service cannot be disabled. No fee is generated when the service is not used.
    • View Call Description: See Calling a Built-in Service.
    • ModelArts Guard: Configure content guard if you have a V2 or higher account level. After built-in services are enabled, ModelArts Guard is enabled by default. .
      To view your account level, log in to the MaaS console, click the username in the upper right corner, click Basic Information, and view the level next to the account name.
      ModelArts Guard blocks harmful content in inputs and outputs during model inference. Enabling it might slow down processing. When disabled, the models rely on their native security features.
      • To enable ModelArts Guard, click More and select Enable ModelArts Guard. In the displayed Enable ModelArts Guard dialog box, read the note and click OK.
      • To disable ModelArts Guard, click More and select Disable ModelArts Guard. In the displayed Disable ModelArts Guard dialog box, read the note, select I have read and agree to the above terms and Content Moderation Disclaimer, and click OK.
  1. Click View Call Description in the Operation column of the subscribed built-in service. Select a version.
  2. On the View Call Description panel, call the built-in service as prompted.
Traffic Control Rules
To ensure fairness in users' calls to the model, MaaS has set up basic traffic limiting. If the limit is exceeded, API requests will fail, and you will need to wait until the traffic limiting conditions are lifted before making another call.
  • Tokens Per Minute (TPM): The number of tokens (input + output) processed per minute.
  • Requests Per Minute (RPM): The number of requests processed per minute.
It is recommended that you send API requests evenly to avoid sending a large number of requests in a short period. Rate limiting policies may be enforced based on QPS (RPM/60). Even if the total request volume is below the per-minute limit, sending a large burst of requests in a short period may trigger rate limiting. This will result in request failure and the return of error code ModelArts.81101 (Too Many Requests). For details about error codes, see Error Codes.
  • Is there any billing example?
    For details about billing items and examples, see Prices of Real-Time Inference Model Services.
  • Can a built-in service be disabled after subscription?
    Built-in services cannot be disabled. No expenditures are generated for unused services.
  • What should I do if the subscription status is frozen when I use a built-in service?
    For details about how to handle the frozen status, see What Should I Do If the Subscription Status is Frozen When I Use a Built-in Service?
  • What should I do if the subscription status is invalid when I use a built-in service?
    If the subscription status is invalid, the resource has been frozen due to arrears and the resource retention period has expired. You can subscribe to the built-in service again.
