Viewing a Built-in Model in Model Square
MaaS provides various open-source models. You can check them on the Model Square. The model details page shows all necessary information. You can choose suitable models for training and inference to incorporate into your enterprise systems.
Billing
Calling built-in services: Billing varies by model type. For details, see Billing Items for MaaS Built-in Model Service.
Accessing the Model Square
- Log in to the MaaS console and select the target region on the top navigation bar.
- In the navigation pane, choose Model Square.
- In the Filter area on the Model Square page, filter models by type, context length, advanced features, series, and supported jobs, or search by model name.
For details about model series, see Model Introduction. The supported filter criteria may vary depending on the region. The following uses CN-Hong Kong as an example.
Table 1 Model filters Filter
Type
Currently, only text models are available.
Context Length
You can filter models by context length, including 256K–1M, 128K–256K, 23K–128K, and 0–32K.
If you select multiple context lengths, the page displays the model set of the selected context lengths.
Advanced Capabilities
You can filter models based on their ability to handle function calls or deep reasoning.
Models
You can filter models by series, including DeepSeek, Qwen3, and GLM.
If you select multiple models, the page displays the collection of the selected model series.
Source
You can filter models by their source.
- Perform the following operations on the target model card on the Model Square page:
Model Introduction
The following table lists the models supported by the MaaS platform. For details about the models, go to the model details page.
| Model Series | Type | Use Case | Supported Language | Model Introduction | |
| GLM | GLM-5.2 | Text generation | Reasoning, coding, and agentic tasks | Chinese and English | GLM-5.2 is the next-generation flagship model from Zhipu AI, open-sourced on June 17, 2026. With state-of-the-art open-source coding and long-horizon task capabilities, it significantly enhances engineering stability in real-world development and improves multi-platform delivery reliability. |
| GLM-5.1 | Text generation | Reasoning, coding, and agentic tasks | Chinese and English | GLM-5.1 is the latest flagship model from Zhipu. It provides enhanced coding capabilities and improved performance in long-horizon tasks. It can autonomously work for up to 8 hours in a single task, covering the entire process from planning and execution to iterative optimization and delivering engineering-level results. While GLM-5.1 matches Claude Opus 4.6 in general intelligence and raw coding proficiency, it significantly outperforms the global frontier in long-horizon sustained execution. It excels at autonomous, multi-stage tasks over extended periods, making it the ideal foundation for building highly resilient autonomous agents and long-horizon coding engines. | |
| DeepSeek | DeepSeek-V4-Pro | Text generation | Q&A and text generation inference | Chinese and English | DeepSeek-V4-Pro is the flagship version of the DeepSeek-V4 series. It adopts a Mixture-of-Experts (MoE) architecture, with trillions of parameters and an ultra-long 1M (one million token) context window. |
| DeepSeek-V4-Flash | Text generation | Q&A and text generation inference | Chinese and English | DeepSeek-V4-Flash is a lightweight, efficient version of the DeepSeek-V4 series. It supports a 1M-token context window while offering faster, cheaper API services through a smaller model size and fewer active parameters. | |
| Qwen3 | Qwen3 | Text generation | Q&A | Chinese and English | The Qwen3 series includes LLMs and multimodal models created by the Qwen team. These models undergo extensive training using vast amounts of language and multimodal data, followed by fine-tuning with top-tier datasets. |
Viewing Built-in Model Details
- In the Filter area on the Model Square page, filter models by type, context length, advanced features, or series, or search by model name.
- Click a model card. On the Model Details page, view the model details, such as the model introduction, version information, and supported capabilities. In the upper right corner of the Model Details page, you can view the operations supported by the model.
The operations supported by different models may vary. Check the console for details.
Calling a Model
MaaS provides commercial-use APIs for inference. After subscribing to a model service, you can directly experience or call the model service without waiting for deployment. The model service is billed based on usage (such as the number of tokens or image generation duration).
- Use either of the following methods to call a model for inference:
- On the Model Square page: Click Model Deployment on a model card.
- On the Model Details page: In the upper right corner of the page, click Model Deployment and select a version. Alternatively, click Deploy on the right of the version area.
- On the View Call Description page, enable or call the model service according to the instructions.
Subscribing to a model service: In the Subscribe to Built-in Services and Try Popular Models Now area, review the information, select I have read and agree to the above terms and MaaS Service Statement, and click Subscribe.
For details about the API key parameters, see Creating an API Key. For details about the API calling parameters, see Model API Calling Specifications.Figure 1 API calling
