Updated on 2026-09-29 GMT+08:00
OpenAI-compatible APIs
This function is only supported in CN-Hong Kong.
API Information
Example Value
API URL
API URL for calling the model service.
https://api-ap-southeast-1.modelarts-maas.com/openai/v1/chat/completions
If the OpenAI SDK is used, set base_url to https://api-ap-southeast-1.modelarts-maas.com/openai/v1.
Authentication request
Provides the server with identity authentication/authorization credentials.
"Authorization": "Bearer $MaaS_API_Key"
Supported Models
You can log in to the MaaS console and enable the following models on the Model Inference > Real-Time Inference > Built-in Services page. On the model details page in the Model Square, you can view detailed information about the models.
Model
Version
Supported Region
Value of model
GLM
GLM-5.3
CN-Hong Kong
glm-5.3
GLM-5.2
CN-Hong Kong
glm-5.2
GLM-5.1
CN-Hong Kong
glm-5.1
DeepSeek
DeepSeek-V4-Pro
CN-Hong Kong
deepseek-v4-pro
DeepSeek-V4-Flash
CN-Hong Kong
deepseek-v4-flash
DeepSeek-V4.1-Flash
CN-Hong Kong
deepseek-v4.1-flash
Request Parameters
Category
Type
Mandatory
General
model
string
Yes
Definition
Model parameter used for generating content. For details about its value, see the model values in Supported models.
N/A
Range
Default Value
N/A
messages
object[]
Yes
Definition
List of messages in a dialog. Different models support different types of messages. For details about the message structure, see the System message, User message, Assistant message, and Tool message.
N/A
System message
messages.role
string
Yes
Definition
Role that sends a message.
N/A
Range
system: A message sent by the system.
Default Value
N/A
messages.content
string/object[]
Yes
Definition
Content of the message sent by the specified role.
N/A
messages.content.type
string
Yes
Definition
Type of the message sent by the specified role.
N/A
Range
text: Text message.
image_url: Image type.
Default Value
N/A
messages.content.text
string
Yes
Definition
Content of a text message.
N/A
Range
N/A
Default Value
N/A
Image information
messages.content.image_url
object
No
Definition
Image content.
  • Only DeepSeek-V4.1-Flash supports this parameter.
  • This parameter is mandatory when messages.content.type is set to image_url.
Range
N/A
Default Value
N/A
messages.content.image_url.url
string
No
Definition
Image address.
  • Image restrictions: A maximum of 600 images are allowed. The size of a single image cannot exceed 32 MB. The image resolution is not limited (recommended resolution: less than 4096 x 2160). The JPEG, PNG, GIF, and WebP formats are supported.
  • Public URLs and Base64-encoded data URIs (for example, data:image/png;base64,...) are supported.
    # PNG image
    data:image/png;base64,{base64_image}
    # JPEG image
    data:image/jpeg;base64,{base64_image}
    # WEBP image
    data:image/webp;base64,{base64_image}
    # GIF image
    data:image/gif;base64,{base64_image}
Range
N/A
Default Value
N/A
User message
messages.role
string
Yes
Definition
N/A
Range
user: A message sent by a user.
Default Value
N/A
messages.content
string/object[]
Yes
Definition
N/A
string
Yes
Definition
N/A
Range
text: Text message.
Default Value
N/A
string
Yes
Definition
N/A
Range
N/A
Default Value
N/A
Assistant message
messages.role
string
Yes
Definition
N/A
Range
assistant: A message returned by the model.
Default Value
N/A
messages.content
string/object[]
Yes
Definition
N/A
messages.tool_calls
array
No
Definition
Tool call records from previous model responses in the dialog history.
This parameter is mandatory when the value of messages.role is tool.
Range
N/A
Default Value
N/A
messages.tool_calls.id
string
Yes
Definition
ID of the tool called by the model.
Range
N/A
Default Value
N/A
messages.tool_calls.type
string
Yes
Definition
Tool type.
Range
function: Function calling.
Default Value
N/A
messages.tool_calls.function
object
Yes
Definition
Function information corresponding to the tool called by the model.
N/A
messages.tool_calls.function.arguments
string
Yes
Definition
JSON parameters generated by the model for calling the function.
Range
N/A
Default Value
N/A
messages.tool_calls.function.name
string
Yes
Definition
Name of the function to be called by the model. This is the user-defined function name.
Range
N/A
Default Value
N/A
Tool message
messages.role
string
Yes
Definition
N/A
Range
tool: A message sent by a function call.
Default Value
N/A
messages.tool_call_id
string
Yes
Definition
Range
N/A
Default Value
N/A
messages.content
string/object[]
Yes
Definition
N/A
Deep thinking settings
chat_template_kwargs
object
No
Definition
Additional keyword parameters passed to the template renderer, which can be used to control whether the model enables deep thinking mode. For details, see Thinking Control for Deep Thinking Models.
N/A
chat_template_kwargs.thinking
boolean
No
Definition
Whether to enable thinking mode.
For details about models that support the thinking mode, see Thinking Control for Deep Thinking Models.
Range
  • true: Enable thinking mode.
  • false: Disable thinking mode.
Default Value
N/A
Model output behavior configuration
max_completion_tokens
integer/null
No
Definition
Maximum length of the model output, including the model answer (content) and CoT (reasoning_content).
After this parameter is set, the token length of the model output does not exceed the value of max_completion_tokens.
  • This parameter cannot be set together with max_tokens. Otherwise, an error is reported.
  • When the thinking mode is off for deep thinking models, max_completions_tokens remains active but only limits the token count of the content section.
Range
The value varies depending on the model. For details, see the maximum output length and maximum CoT length on the model details page of the MaaS console.
Default Value
N/A
max_tokens
integer/null
No
Definition
Maximum length of a model response, in tokens.
  • The model response does not contain the CoT content.
    Model response = Model output – Model CoT (if any).
  • The total length of output tokens is also restricted by the model's context length.
Range
The value varies depending on the model. For details, see the maximum output length on the model details page of the MaaS console.
Default Value
  • DeepSeek-V4.1-Flash: 64K
  • Other models: 4K
continue_final_message
boolean
No
Definition
Specifies whether to enable prefix continuation.
To enable this function, set add_generation_prompt to false. Otherwise, an error is reported.
Range
  • true: Enable prefix continuation.
  • false: Disable prefix continuation.
Default Value
false
boolean
No
Definition
Whether to add the prompt generated by the model to the chat template. This is a parameter used by the chat template in the tokenizer configuration of the model.
This parameter and continue_final_message are mutually exclusive and cannot be both set to true.
Range
  • true: Add the prompt generated by the model to the chat template.
  • false: Do not add the prompt generated by the model to the chat template.
Default Value
true
temperature
float/null
No
Definition
Sampling temperature, used to control the randomness of the content generated by the model.
A higher value (for example, greater than 1) will make the model output more random, divergent, and creative, while a lower value (for example, 0.1) will make the output more focused, deterministic, and conservative.
It is recommended that you adjust either temperature or top_p.
Range
[0,2]
Default Value
Some models apply special handling to inputs:
  • DeepSeek-V4: In thinking mode, the value is always 1.0, regardless of the user input.
  • For GLM-5.3, the default value is 1.0.
For other models, the input is used if provided; otherwise, it defaults to 0.6.
top_p
float/null
No
Definition
Nucleus sampling probability threshold, used to control the diversity of the content generated by the model. Similar to the temperature parameter but operates differently, allowing finer control over the vocabulary range of the model's output.
When set close to 0, the model samples from only the most probable tokens, resulting in very conservative and highly deterministic outputs. When set close to 1, there is virtually no restriction on the vocabulary, leading to more random and divergent outputs.
Range
[0,1]
Default Value
  • GLM-5.3: Defaults to 0.95.
  • Other models: 0.7
top_k
integer
No
Definition
Controls the model to select only from the top k most probable tokens during generation, influencing the randomness of the generated text. Higher values increase randomness, while lower values enhance determinism.
N/A
Range
>=0
Default Value
20
frequency_penalty
number/null
No
Definition
Frequency penalty coefficient, which is an important parameter used to control the diversity of model outputs.
The probability of a token reappearing decreases proportionally based on its frequency in the generated text. The more frequently a token appears, the lower its likelihood of being used again.
DeepSeek-V4 series: This parameter is not supported.
DeepSeek-V4.1-Flash: This parameter is not supported.
Range
[-2,2]
  • 0: No penalty is applied.
  • Positive value: Increases the penalty. A larger value makes the model more likely to introduce new tokens and topics to avoid repetition.
  • Negative value: Reduces the penalty (acting as a reward). The model becomes more inclined to reuse previously generated words, which often results in repetitive and verbose text (generally not recommended).
Default Value
0
presence_penalty
number/null
No
Definition
Presence penalty coefficient, which is an important parameter used to control the diversity of model outputs. This reduces the probability that the model will repeatedly use previously mentioned tokens or topics, thereby encouraging it to generate new content.
As long as a token has appeared at least once in the previously generated text, the model imposes a fixed penalty on it to reduce the probability of it being selected again. The model determines this penalty based solely on whether the token has appeared so far. A positive value increases the likelihood of the model generating novel content.
DeepSeek-V4 and GLM series: This parameter is not supported.
Range
[-2,2]
Default Value
0
logprobs
boolean/null
No
Definition
Log probability. Controls whether the model returns the log probabilities of the output tokens.
N/A
Range
  • true: Log probabilities are returned.
  • false: Log probabilities are not returned.
Default Value
false
stream
boolean/null
No
Definition
Determines whether the response content is returned as a stream.
N/A
Range
  • false: Returns results once all content has been generated by the model.
  • true: Returns content piece by piece, ending with data: [DONE].
Default Value
false
stream_options
object/null
No
Definition
Options for streaming responses.
This parameter can be set only when stream is true.
stream_options.include_usage
boolean
No
Definition
Indicates whether to output token usage information of the current request before the streaming response ends.
Currently, this feature cannot be disabled.
Range
  • true: An additional chunk is returned before data: [DONE]. In this chunk, the usage field displays the token usage of the entire request, and the choices field is an empty array.
  • false: The token usage information of this request is not returned.
Default Value
true
stop
string / string[] / null
No
Definition
When the model encounters the string specified in the stop field, the generation stops and the string itself does not appear in the response. The stop token does not hit the token in the CoT, but only hits the part in the formal answer content.
A maximum of four strings are supported.
Range
N/A
Default Value
N/A
reasoning_effort
string
No
Definition
Controls the reasoning intensity.
  • This field takes effect only in thinking mode.
  • Involved models: DeepSeek-V4 series, GLM-5.2, GLM-5.3, GLM-5.2-Arkts-Spark, and DeepSeek-V4.1-Flash
Range
  • low: enhanced reasoning
  • high or max: deep reasoning
GLM-5.3:
  • max or high: deep reasoning
GLM-5.2-Arkts-Spark and GLM-5.2:
  • max or xhigh: deep reasoning
  • high, medium, or low: enhanced reasoning
  • minimal or none: The model gives up thinking.
    • xhigh is mapped to max.
    • low or medium is mapped to high.
DeepSeek-V4 series: max or high
Default Value
GLM-5.2-Arkts-Spark, GLM-5.3, and GLM-5.2: max
DeepSeek-V4.1-Flash and DeepSeek-V4 series: high
Tool calling
tools
object[]/null
No
Definition
List of tools available for the model to call, which may be included in the model's response. Configure this structure when you require the model to specify the tools to be called.
N/A
tools.type
string
Yes
Definition
Tool type.
N/A
Range
Default Value
N/A
tools.function
object
Yes
Definition
Controls whether the model's response contains the tools to be called.
N/A
tools.function.name
string
Yes
Definition
Name of the function to be called.
N/A
Range
N/A
Default Value
N/A
tools.function.description
string
No
Definition
Description of the function to be called. The model will determine if the tool is needed for the current task based on this description.
N/A
Range
N/A
Default Value
N/A
tools.function.parameters
object
No
Definition
Function request parameters, described in JSON format. Example:
  "type": "object",
  "properties": {
    "parameter name": {
      "type": "string | number | boolean | object | array",
      "description": "Parameter description"
  "required": ["Mandatory parameters"]
Parameters must conform to JSON specifications.
N/A
tool_choice
string/object
No
Definition
Controls how the model calls tools. For details about the types supported by the model, see Tool Choices for Models.
N/A
Range
  • none: Do not call any tool.
  • auto: The model decides whether to call tools or not.
  • named: The model must call the specified function, as defined by the tool_choice.type and tool_choice.function fields.
Default Value
  • If no tools are provided, the default value is none.
  • If tools are provided, the default value is auto.
tool_choice.type
string
Yes
Definition
Type of the call, which should be function here.
N/A
Range
Default Value
N/A
object
Yes
Definition
Information about the function to be called by the model.
N/A
tool_choice.function.name
string
Yes
Definition
Name of the function to be called by the model. This function must be declared in the tools parameter list.
N/A
Range
N/A
Default Value
N/A
Response Parameters (Non-Streaming)
Type
created
integer
Definition
Unix timestamp (in seconds) indicating when the request was created.
Range
N/A
id
string
Definition
Unique identifier of this request.
Range
N/A
model
string
Definition
Model parameter used in this request.
Range
object
string
Definition
Model API type.
Range
chat.completion.
choices
object[]
Definition
A list of model-generated completion choices for this request.
choices.finish_reason
string
Definition
Reason why the model stopped generating:
Range
  • stop: The model output ended naturally or hit the field specified in the request parameter stop.
  • length: The model output is truncated because the model output limit is reached.
  • tool_calls: The model triggered tool calls.
choices.index
integer
Definition
Index of the current element in the choices list.
Range
N/A
choices.message
object
Definition
Content generated by the model.
choices.message.role
string
Definition
The role of the author of this message.
Range
  • assistant: A message returned by the model.
  • tool: A message sent by a function call.
choices.message.content
string
Definition
Message content generated by the model.
Range
N/A
choices.message.reasoning_content
string/null
Definition
CoT content generated by the model, only returned by deep thinking models.
Range
N/A
choices.message.tool_calls
object[]/null
Definition
Tool call information generated by the model, returned only if tool calls were triggered.
choices.message.tool_calls.id
string
Definition
ID of the called tool.
Range
N/A
choices.message.tool_calls.type
string
Definition
Tool type.
Range
choices.message.tool_calls.function
object
Definition
Function called by the model.
choices.message.tool_calls.function.name
string
Definition
Name of the function called by the model.
Range
N/A
choices.message.tool_calls.function.arguments
string
Definition
JSON input generated by the model for calling the function.
Range
N/A
choices.logprobs
object/null
Definition
Log probability information for the content.
choices.logprobs.content
object[]/null
Definition
Log probability information for each token in the generated message.
choices.logprobs.content.token
string
Definition
Token in the generated message.
Range
N/A
choices.logprobs.content.logprob
float
Definition
Log probability of the token in the generated message.
Range
N/A
choices.logprobs.content.bytes
integer[]/null
Definition
List of integers representing the UTF-8 byte values of the token. This field is empty if the token does not have a valid UTF-8 representation.
usage
object
Definition
Token usage of this request.
usage.completion_tokens
integer
Definition
The number of tokens consumed by the model to generate the completion response.
Range
N/A
usage.prompt_tokens
integer
Definition
The number of tokens consumed by the model to process the input prompt.
Range
N/A
usage.total_tokens
integer
Definition
The total number of tokens consumed by this request (including input and output tokens).
Range
N/A
usage.completion_tokens_details
object
Definition
A detailed breakdown of the tokens consumed by the model's generated output.
usage.completion_tokens_details.reasoning_tokens
integer
Definition
The number of tokens consumed by the model to generate the chain-of-thought output.
Range
N/A
usage.prompt_tokens_details
object
Definition
A detailed breakdown of the input prompt tokens provided to the model.
usage.prompt_tokens_details.cached_tokens
integer
Definition
Token usage of the cached input content.
Range
N/A
service_tier
string
Definition
Service tier used for this request.
Range
default
Response Parameters (Streaming)
Type
created
integer
Definition
Range
N/A
id
string
Definition
Range
N/A
model
string
Definition
Range
object
string
Definition
Fixed as chat.completion.chunk.
choices
object[]
Definition
string
Definition
Reason why the model stops generating tokens.
Range: reason why the model stops generating tokens. Range:
  • stop: The model output ends naturally or is truncated due to matching the field specified in the stop request parameter.
  • tool_calls: The model calls tools.
choices.index
integer
Definition
Range
N/A
choices.delta
object
Definition
Incremental output from the model.
choices.delta.role
string
Definition
Range
choices.delta.content
string
Definition
Range
N/A
choices.delta.reasoning_content
string/null
Definition
The model's CoT process.
Range
N/A
choices.delta.tool_calls
object[]/null
Definition
Tool call information generated by the model.
choices.delta.tool_calls.id
string
Definition
Range
N/A
choices.delta.tool_calls.type
string
Definition
Tool type. Currently, it only supports function.
Range
choices.delta.tool_calls.function
object
Definition
choices.delta.tool_calls.function.name
string
Definition
Range
N/A
choices.delta.tool_calls.function.arguments
string
Definition
The model does not always generate valid JSON, and may fabricate some parameters that are not defined in your function parameter specifications. Before calling a function, verify that these parameters are valid in your code.
Range
N/A
choices.logprobs
object/null
Definition
object[]/null
Definition
string
Definition
Range
N/A
float
Definition
Range
N/A
integer[]/null
Definition
usage
object
Definition
integer
Definition
Range
N/A
usage.prompt_tokens
integer
Definition
Range
N/A
usage.total_tokens
integer
Definition
Range
N/A
object
Definition
integer
Definition
Range
N/A
object
Definition
integer
Definition
Range
N/A
service_tier
string
Definition
Range
default
first_token_return_time
float
Definition
Time when the model returned the first token of the chunk.
Range
N/A
Model
Default Mode
Thinking Control
GLM-5.3
Deep thinking
Currently, this parameter cannot be disabled.
GLM-5.2
GLM-5.1
Deep thinking
"chat_template_kwargs": {"thinking": True}
DeepSeek-V4.1-Flash
DeepSeek-V4-Flash
DeepSeek-V4-Pro
Deep thinking
Model
Supported Tool Choice
GLM-5.3
GLM-5.2
GLM-5.1
  • none
  • auto
  • named
DeepSeek-V4.1-Flash
DeepSeek-V4-Flash
DeepSeek-V4-Pro
  • none
  • auto
  • named
Example 1: Streaming response
Example request:
import requests
import json
if __name__ == '__main__':
        url = "https://api-ap-southeast-1.modelarts-maas.com/openai/v1/chat/completions" # API URL
    api_key = "MAAS_API_KEY"  # Replace MAAS_API_KEY with the obtained API key.
    # Send request.
    headers = {
        'Content-Type': 'application/json',
        'Authorization': f'Bearer {api_key}'
    data = {
        "model": "glm-5.2",  # Model parameter. You can change the model parameter as required.
        "stream":True,
        "messages": [
            {"role": "system", "content": "You are a helpful assistant."},
            {"role": "user", "content": "Hello"}
    response = requests.post(url, headers=headers, data=json.dumps(data), verify=False)
    # Print result.
    print(response.status_code)
    print(response.text)
Run the following commands in the Linux environment:
curl --request POST \
  --url https://api-ap-southeast-1.modelarts-maas.com/openai/v1/chat/completions \
  --header 'authorization: Bearer $MAAS_API_KEY' \
  --header 'content-type: application/json' \
  --data '{
  "model": "glm-5.2",
  "stream": true,
  "messages": [
      "role": "system",
      "role": "user",
      "content": "Hello"
Example response:
data: {"id":"8697e7dad55f4ad5ae65f006ba18f2fc","object":"chat.completion.chunk","created":1782266611,"model":"glm-5.2","choices":[{"index":0,"delta":{"content":"Hello!"}}],"service_tier":"default","first_token_return_time":1.7822666148251362E9}
data: {"id":"8697e7dad55f4ad5ae65f006ba18f2fc","object":"chat.completion.chunk","created":1782266611,"model":"glm-5.2","choices":[{"index":0,"delta":{"content":" How"}}],"service_tier":"default","first_token_return_time":1.7822666148726385E9}
data: {"id":"8697e7dad55f4ad5ae65f006ba18f2fc","object":"chat.completion.chunk","created":1782266611,"model":"glm-5.2","choices":[{"index":0,"delta":{"content":"can I help"}}],"service_tier":"default","first_token_return_time":1.7822666149221663E9}
data: {"id":"8697e7dad55f4ad5ae65f006ba18f2fc","object":"chat.completion.chunk","created":1782266611,"model":"glm-5.2","choices":[{"index":0,"delta":{"content":"you"}}],"service_tier":"default","first_token_return_time":1.7822666149709113E9}
data: {"id":"8697e7dad55f4ad5ae65f006ba18f2fc","object":"chat.completion.chunk","created":1782266611,"model":"glm-5.2","choices":[{"index":0,"delta":{"content":"?"}}],"service_tier":"default","first_token_return_time":1.782266615021146E9}
data: {"id":"8697e7dad55f4ad5ae65f006ba18f2fc","object":"chat.completion.chunk","created":1782266611,"model":"glm-5.2","choices":[{"index":0,"delta":{"content":""},"finish_reason":"stop"}],"service_tier":"default","first_token_return_time":1.782266615021146E9}
data: {"id":"8697e7dad55f4ad5ae65f006ba18f2fc","object":"chat.completion.chunk","created":1782266611,"model":"glm-5.2","choices":[],"usage":{"prompt_tokens":20,"total_tokens":134,"completion_tokens":114,"prompt_tokens_details":{"cached_tokens":0},"completion_tokens_details":{"reasoning_tokens":105}},"service_tier":"default","first_token_return_time":1.7822666150211895E9}
data: [DONE]
Example 2: Prefix Continuation
Example request:
import requests
import json
    # Send request.
    headers = {
    data = {
        "model": "DeepSeek-V4-Flash",
        "continue_final_message": True,
        "add_generation_prompt": False,
        "messages": [
          "role": "user",
      "content": "You are a calculator. Please calculate: 1 + 1."
          "role": "assistant",
          "content": "="
       "stream": False
    # Print result.
  --data '{
  "continue_final_message": true,
  "add_generation_prompt": false,
  "messages": [
      "role": "user",
      "content": "="
  "stream": false
Example response:
  "id": "784f6f4091a7430b993c561bc4f1d216",
  "object": "chat.completion",
  "created": 1782268057,
  "choices": [
      "index": 0,
      "message": {
        "content": " 2"
      "finish_reason": "stop"
  "usage": {
    "prompt_tokens": 21,
    "total_tokens": 24,
    "completion_tokens": 3,
    "prompt_tokens_details": {
      "cached_tokens": 0
    "completion_tokens_details": {
      "reasoning_tokens": 0
  "service_tier": "default"
Example 3: Multi-Turn Conversation
Example request:
import requests
import json
import requests
import json
    url = "https://api-ap-southeast-1.modelarts-maas.com/v2/chat/completions"  # API URL
    # Send request.
    headers = {
    data = {
        "model": "glm-5.2",
        "messages": [
                "role": "system",
                "role": "user",
               "content": "Recommend a programming book for beginners."
               "content": "I recommend Python Crash Course: A Hands-On, Project-Based Introduction to Programming. It is perfect for beginners with no prior programming experience."
                "role": "user",
              "content": "I want to learn data analysis. Is this book suitable for that?"
        "stream": False
    # Print result.
  --data '{
  "model": "glm-5.2",
  "messages": [
      "role": "system",
      "role": "user",
      "role": "user",
  "stream": false
Example response:
  "id": "814f0581080f422bb06ccff00dc3ea51",
  "created": 1782269006,
  "model": "glm-5.2",
  "choices": [
      "index": 0,
      "message": {
        "content": "That's a good choice. Python is the dominant language for data analysis, and the foundational chapters of this book will help you build a solid base. Once you finish it, you can move on to Python for Data Analysis to focus specifically on your data analysis skills."
  "usage": {
    "prompt_tokens": 65,
    "total_tokens": 103,
    "completion_tokens": 38,
      "cached_tokens": 0
Example 4: Tool Calling
Example request:
import requests
import json
    # Send request.
    headers = {
    data = {
        "model": "glm-5.2",
        "messages": [
                "role": "system",
                "role": "user",
            "content": "What is the weather in Beijing today?"
                "tool_calls": [
                        "id": "call_e8d8a81c1f3942868443360f",
                        "type": "function",
                        "function": {
                            "name": "get_weather",
                        "arguments": "{\"city\": \"Beijing\", \"unit\": \"celsius\"}"
                "role": "tool",
                "tool_call_id": "call_e8d8a81c1f3942868443360f",
            "content": "{\"city\": \"Beijing\", \"temperature\": 26, \"unit\": \"celsius\", \"condition\": \"Sunny\"}"
        "tools": [
                "type": "function",
                "function": {
                "description": "Get the current weather for a specified city.",
                    "parameters": {
                        "type": "object",
                        "properties": {
                            "city": {
                                "type": "string",
                            "description": "City name, for example, Beijing."
                            "unit": {
                                "type": "string",
                                "enum": [
                                    "celsius",
                                    "fahrenheit"
                            "description": "Temperature unit"
                        "required": [
                            "city"
        "tool_choice": "auto",
        "stream": False
    # Print result.
  --data '{
  "model": "glm-5.2",
  "messages": [
      "role": "system",
      "role": "user",
      "content": null,
      "tool_calls": [
          "type": "function",
          "function": {
      "role": "tool",
  "tools": [
      "type": "function",
      "function": {
        "parameters": {
          "type": "object",
          "properties": {
            "city": {
              "type": "string",
            "unit": {
              "type": "string",
              "enum": [
                "celsius",
                "fahrenheit"
          "required": [
            "city"
  "stream": false
Example response:
  "id": "d41eba20c8a545c69864003a3fcd5ae2",
  "created": 1782270016,
  "model": "glm-5.2",
  "choices": [
      "index": 0,
      "message": {
        "content": "Here is the weather information for Beijing today: \n\n- 🌤️ Weather Conditions: Sunny \n- 🌡️ Temperature: 26°C \n\n It is sunny in Beijing today with a comfortable temperature of 26°C, making it a perfect day to go out! If you need to check the weather for any other city, feel free to let me know anytime~"
  "usage": {
    "prompt_tokens": 246,
    "total_tokens": 306,
    "completion_tokens": 60,
      "cached_tokens": 0
Example 5: Image Understanding (Multiple Images)
Example request:
import requests
import json
import base64
#  Base64-encode the image.
def encode_image(image_path):
    with open(image_path, "rb") as image_file:
        return base64.b64encode(image_file.read()).decode("utf-8")
base64_image = encode_image("test.png") # Replace it with the actual image path.
    # Send request.
    headers = {
    data = {
        "model": "deepseek-v4.1-flash",  # Model parameter
        "messages": [
                "role": "user",
                "content": [
                        "type": "text",
                        "text": "Describe the content in the two images"
                        "type": "image_url",
                        "image_url": {
                            "url": f"data:image/png;base64,{base64_image}"
                        "image_url": {
                            "url":"https://example.com/example.png"
    response = requests.post(url, headers=headers, data=json.dumps(data))
    # Print result.
  --url "https://api-ap-southeast-1.modelarts-maas.com/openai/v1/chat/completions" \
  --data '{
  "messages": [
            "role": "user",
            "content": [
                    "type": "text",
                     "image_url": {
                          "url": "data:image/png;base64,$BASE64_IMAGE"
                      "image_url": {
