Help Center/
      Cloud Container Engine/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        Workload/
        Scheduling Policies/
      Why Cannot a Pod Be Scheduled to a Node?
- Check whether the node and Docker are normal. For details, see Check Item 7: Whether Internal Components Are Normal.
- If the node and Docker are normal, check whether an affinity policy is configured for the pod. For details, see Check Item 3: Affinity and Anti-Affinity Configuration of the Workload.
- Check whether the resources on the node are sufficient. If the resources are insufficient, expand the capacity or add nodes.
   Parent topic: Scheduling Policies
