What Should I Do If a Pod Remains in the Terminating State?
Symptom
When obtaining workloads in a namespace, you may come across pods that are in the Terminating state.
For example, if you use the command below to obtain pods in the aos namespace, you may notice that some pods are in the Terminating state:
#kubectl get pod -n aos
NAME                              READY      STATUS         RESTARTS   AGE
aos-apiserver-5f8f5b5585-s9l92     1/1       Terminating    0          3d1h
aos-cmdbserver-789bf5b497-6rwrg    1/1       Running        0          3d1h
aos-controller-545d78bs8d-vm6j9    1/1       Running        3          3d1h
  Running kubectl delete pods <podname> -n <namespace> cannot delete the pods.
kubectl delete pods aos-apiserver-5f8f5b5585-s9l92 -n aos
Possible Cause
The following lists some possible causes:
- The node that runs a terminating pod is abnormal. When a node is unavailable, CCE migrates pods on the node and sets the pods running on the node to the Terminating state.
    After the node is restored, the pods in the Terminating state will be automatically deleted.
- A container is unresponsive. If a container within a pod fails to respond to the SIGTERM signal while being terminated, the pod can become stuck in the Terminating state.
- There are unfinished requests or resource occupation within a pod. If a process within a pod continues to run for an extended period, it may prevent the pod from being terminated and cause it to enter the Terminating state.
- A pod has finalizers specified. Finalizers are used to clean up resources before they are deleted. If a pod has finalizers specified and the cleanup process is paused or unresponsive, the pod will remain in the Terminating state.
- A pod has terminationGracePeriodSeconds configured. Once a graceful exit time is set for a pod, it will enter the Terminating state upon termination and be automatically deleted after exiting gracefully.
Solution
   Before forcibly deleting a pod, it is important to consider the potential risks to your services. This is especially true for StatefulSet pods, because there is a higher chance of data inconsistency and abnormal container exits. Take the time to evaluate these risks before proceeding with the operation. For details, see Force Delete StatefulSet Pods.
Run the following command to forcibly delete the pods created in any ways:
kubectl delete pod <pod> -n <namespace> --grace-period=0 --force
Run the following command to delete the terminating pod described at the very beginning of this section:
kubectl delete pod aos-apiserver-5f8f5b5585-s9l92 -n aos --grace-period=0 --force
