Updating the HTTPS Certificate for a LoadBalancer Ingress
If the HTTPS certificate for a LoadBalancer ingress is about to expire or has expired, follow the operations provided in this section to update it.
Application Scenarios
Scenario |
Description |
LoadBalancer Service certificate |
To update an HTTPS certificate, create a LoadBalancer Service certificate and select it when modifying the ingress. Alternatively, modify the certificate on the ELB certificate management page. |
TLS certificate |
To update an HTTPS certificate, update the target secret in the cluster. CCE will then automatically configure the certificate (starting with k8s_plb_default) on the ELB. The certificate automatically created by CCE cannot be modified or deleted on the ELB. |
Procedure for TLS Secret Certificates
- In the navigation pane, choose ConfigMaps and Secrets. In the right pane, click the Secrets tab, find the secret used by the ingress, and click Update.
- Modify the certificate file in the secret and click OK to update the secret. CCE will automatically synchronize the certificate to the ELB.
Procedure for LoadBalancer Service Certificates
- In the navigation pane, choose Services & Ingresses. Then, click the Ingresses tab, locate the row containing the target ingress, and choose More > Update in the Operation column.
- Set Certificate Source to ELB server certificate, select a new server certificate, and click OK to update the ingress.
