Configuring QoS for a Pod
Bandwidth preemption occurs between different containers deployed on the same node, which may cause service jitter. You can configure bandwidth limitation for the pod to solve this problem.
Specifications
The following table lists the bandwidth limitation specifications of pods.
Specifications
Tunnel
VPC
Cloud Native Network 2.0
Supported cluster versions
All versions
Clusters of v1.19.10 and later
Egress bandwidth limitation
Supported
Supported
Supported
Ingress bandwidth limitation
Supported
Supported
Supported
Scenarios where bandwidth limitation is not supported
None
None
  • Pod access to cloud service CIDR blocks such as 100.125.0.0/16
  • Pod health check
Bandwidth limitation range
Only the rate limit in the unit of Mbit/s or Gbit/s is supported, for example, 100 Mbit/s and 1 Gbit/s. The minimum value is 1 Mbit/s and the maximum value is 4.29 Gbit/s.
  • Pod bandwidth limitation applies to regular containers (runC as the container runtime), not secure containers (Kata Containers as the container runtime).
  • Pod bandwidth limitation does not apply to hostNetwork pods.
Using the CCE Console
When creating a workload on the console, you can set pod ingress and egress bandwidth limits by clicking Network Configuration in the Advanced Settings area.
Using kubectl
You can add annotations to a workload to specify its egress and ingress bandwidth.
apiVersion: apps/v1
kind: Deployment
  namespace: default
  labels:
    app: test
  replicas: 2
  selector:
    matchLabels:
      app: test
  template:
      labels:
        app: test
      annotations:
        kubernetes.io/ingress-bandwidth: 100M
        kubernetes.io/egress-bandwidth: 100M
      containers:
        - name: container-1
          image: nginx:alpine
          imagePullPolicy: IfNotPresent
      imagePullSecrets:
        - name: default-secret
  • kubernetes.io/ingress-bandwidth: ingress bandwidth of the pod
  • kubernetes.io/egress-bandwidth: egress bandwidth of the pod
If these two parameters are not specified, the bandwidth is not limited.
After modifying the ingress or egress bandwidth limit of a pod, restart the container for the modification to take effect. After annotations are modified in a pod not managed by workloads, the container will not be restarted, so the bandwidth limits do not take effect. You can create a pod again or manually restart the container.
