Volcano Scheduler
Introduction
Volcano is a batch processing platform based on Kubernetes. It provides a series of features required by machine learning, deep learning, bioinformatics, genomics, and other big data applications, as a powerful supplement to Kubernetes capabilities.
Volcano provides general computing capabilities such as high-performance job scheduling, heterogeneous chip management, and job running management. It accesses the computing frameworks for various industries such as AI, big data, gene, and rendering and schedules up to 1000 pods per second for end users, greatly improving scheduling efficiency and resource utilization.
Volcano provides job scheduling, job management, and queue management for computing applications. Its main features are as follows:
  • Diverse computing frameworks, such as TensorFlow, MPI, and Spark, can run on Kubernetes in containers. Common APIs for batch computing jobs through CRD, various plugins, and advanced job lifecycle management are provided.
  • Advanced scheduling capabilities are provided for batch computing and high-performance computing scenarios, including group scheduling, preemptive priority scheduling, packing, resource reservation, and task topology.
  • Queues can be effectively managed for scheduling jobs. Complex job scheduling capabilities such as queue priority and multi-level queues are supported.
Volcano has been open-sourced in GitHub at https://github.com/volcano-sh/volcano.
Install and configure the Volcano add-on in CCE clusters. For details, see Volcano Scheduling.
When using Volcano as a scheduler, use it to schedule all workloads in the cluster. This prevents resource scheduling conflicts caused by simultaneous working of multiple schedulers.
Notes and Constraints
If the Volcano Scheduler add-on is upgraded from 1.4.7 or earlier to a version later than 1.4.7, the webhooks.admissionReviewVersions field information in the new version may be incompatible with that in the old version. As a result, VolcanoJob (vcjob) resources cannot be created.
Installing the Add-on
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons, locate Volcano Scheduler on the right, and click Install.
  2. On the Install Add-on page, configure the specifications as needed.
    • If you selected Preset, the system will configure the number of pods and resource quotas for the add-on based on the preset specifications. You can see the configurations on the console.
    • If you selected Custom, you can adjust the number of pods and resource quotas as needed. High availability is not possible with a single pod. If an error occurs on the node where the add-on instance runs, the add-on will fail.
      The resource quotas of the volcano-admission component are related to the cluster scale. For details, see Table 1. The resource quotas of volcano-controller and volcano-scheduler are related to the number of cluster nodes and pods. The recommended values are as follows:
      • If the number of nodes is less than 100, retain the default configuration. The requested vCPUs are 500m, and the limit is 2000m. The requested memory is 500 MiB, and the limit is 2000 MiB.
      • If the number of nodes is greater than 100, increase the requested vCPUs by 500m and the requested memory by 1000 MiB each time 100 nodes (10,000 pods) are added. Increase the vCPU limit by 1500m and the memory limit by 1000 MiB.
        Recommended formula for calculating the requested value:
        • Requested vCPUs: Calculate the number of target nodes multiplied by the number of target pods, perform interpolation search based on the number of nodes in the cluster multiplied by the number of target pods in Table 2, and round up the request value and limit value that are closest to the specifications.
          For example, for 2000 nodes and 20,000 pods, Number of target nodes x Number of target pods = 40 million, which is close to the specification of 700/70,000 (Number of cluster nodes x Number of pods = 49 million). According to the following table, set the requested vCPUs to 4000m and the limit value to 5500m.
        • Requested memory: It is recommended that 2.4 GiB memory be allocated to every 1000 nodes and 1 GiB memory be allocated to every 10,000 pods. The requested memory is the sum of these two values. (The obtained value may be different from the recommended value in Table 2. You can use either of them.)
          Requested memory = Number of target nodes/1000 × 2.4 GiB + Number of target pods/10,000 × 1 GiB
          For example, for 2000 nodes and 20,000 pods, the requested memory is 6.8 GiB (2000/1000 × 2.4 GiB + 20,000/10,000 × 1 GiB).
      Table 1 Recommended requested resources and resource limits for volcano-admission
      Cluster Scale
      CPU Request(m)
      vCPU Limit (m)
      Requested Memory (MiB)
      Memory Limit (MiB)
      50 nodes
      200
      500
      500
      500
      200 nodes
      500
      1000
      1000
      2000
      1000 or more nodes
      1500
      2500
      3000
      4000
      Table 2 Recommended requested resources and resource limits for volcano-controller and volcano-scheduler
      Nodes/Pods in a Cluster
      CPU Request (m)
      CPU Limit (m)
      Memory Request (MiB)
      Memory Limit (MiB)
      50/5000
      500
      2000
      500
      2000
      100/10000
      1000
      2500
      1500
      2500
      200/20000
      1500
      3000
      2500
      3500
      300/30000
      2000
      3500
      3500
      4500
      400/40000
      2500
      4000
      4500
      5500
      500/50000
      3000
      4500
      5500
      6500
      600/60000
      3500
      5000
      6500
      7500
      700/70000
      4000
      5500
      7500
      8500
  3. Configure the extended functions supported by the add-on.
    • Descheduling: After this function is enabled, the volcano-descheduler component is automatically deployed. The scheduler will evict and reschedule pods that do not meet your policy configuration requirements. This helps to balance cluster load and reduce resource fragmentation. For details, see Descheduling.
    • NUMA Topology Scheduling: After this function is enabled, the resource-exporter component is automatically deployed. The scheduler will schedule pods in NUMA affinity mode, which enhances the performance of high-performance training jobs. For details, see NUMA Affinity Scheduling.
  4. Configure deployment policies for the add-on pods.
    • Scheduling policies do not take effect on add-on pods of the DaemonSet type.
    • When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on cannot run.
    Table 3 Configurations for add-on scheduling
    Multi-AZ Deployment
    • Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
    • Forcible: Deployment pods of the add-on are forcibly scheduled to nodes in different AZs. There can be at most one pod in each AZ. If nodes in a cluster are not in different AZs, some add-on pods cannot run properly. If a node is faulty, add-on pods on it may fail to be migrated.
    Node Affinity
    • Not configured: Node affinity is disabled for the add-on.
    • Specify node: Specify the nodes where the add-on is deployed. If you do not specify the nodes, the add-on will be randomly scheduled based on the default cluster scheduling policy.
    • Specify node pool: Specify the node pool where the add-on is deployed. If you do not specify the node pools, the add-on will be randomly scheduled based on the default cluster scheduling policy.
    • Customize affinity: Enter the labels of the nodes where the add-on is to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on will be randomly scheduled based on the default cluster scheduling policy.
    Toleration
    Using both taints and tolerations allows (not forcibly) the add-on Deployment to be scheduled to a node with the matching taints, and controls the Deployment eviction policies after the node where the Deployment is located is tainted.
    The add-on adds the default tolerance policy for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints, respectively. The tolerance time window is 60s.
    For details, see Configuring Tolerance Policies.
  5. Click Install.
    After the add-on is installed, you can choose Settings in the navigation pane, switch to the Scheduling tab, select Volcano scheduler, and find the corresponding expert mode. You can customize advanced scheduling policies based on actual service scenarios. The following is an example:
    admission_kube_api_qps: 200
    admissions: /jobs/mutate,/jobs/validate,/podgroups/mutate,/pods/validate,/pods/mutate,/queues/mutate,/queues/validate,/eas/pods/mutate,/eas/pods/validate,/npu/jobs/validate,/resource/validate,/resource/mutate,/workloadbalancer/balancer/validate,/workloadbalancer/balancerpolicytemplate/validate
    annotations: {}
    colocation_enable: 'false'
    controller_kube_api_qps: 200
    default_scheduler_conf:
      actions: allocate, backfill, preempt
      metrics:
        interval: 30s
        type: ''
      tiers:
        - plugins:
            - name: priority
            - enableJobStarving: false
              enablePreemptable: false
            - name: conformance
        - plugins:
            - enablePreemptable: false
            - name: predicates
            - name: nodeorder
        - plugins:
            - name: cce-gpu-topology-predicate
            - name: cce-gpu-topology-priority
            - name: xgpu
        - plugins:
            - name: nodelocalvolume
            - name: nodeemptydirvolume
            - name: nodeCSIscheduling
            - name: networkresource
    deschedulerPolicy:
      profiles:
        - name: ProfileName
          pluginConfig:
            - args:
                nodeFit: true
            - args:
                evictableNamespaces:
                  exclude:
                    - kube-system
                thresholds:
                  cpu: 20
                  memory: 20
            - args:
                  exclude:
                    - kube-system
                metrics:
                  type: prometheus_adaptor
                nodeFit: true
                targetThresholds:
                  cpu: 80
                  memory: 85
                thresholds:
                  cpu: 30
                  memory: 30
          plugins:
            balance:
              enabled: null
    descheduler_enable: 'false'
    deschedulingInterval: 10m
    enable_workload_balancer: false
    oversubscription_method: nodeResource
    oversubscription_profile_period: 300
    oversubscription_ratio: 60
    recommendation_enable: ''
    scheduler_kube_api_qps: 200
    update_pod_status_qps: 50
    workload_balancer_score_annotation_key: ''
    workload_balancer_third_party_types: ''
    Table 4 Advanced Volcano configuration parameters
    Function
    Function
    Basic scheduling functions
    QPS of requests sent by volcano-admission to Kubernetes API server
    Value range: greater than 0; parameter type: float
    QPS of requests sent by volcano-controller to Kubernetes API server
    QPS of requests sent by volcano-scheduler to Kubernetes API server
    QPS of the requests for updating the pod status by volcano-scheduler
    Value range: greater than 0; parameter type: int
    Used to schedule pods. It consists of a series of actions and plugins and features high scalability. You can specify and implement actions and plugins based on your requirements.
    It consists of:
    • actions: defines the types and sequence of actions to be executed by the scheduler.
    • tiers: configures the plugin list.
    default_scheduler_conf.actions
    Actions to be executed in each scheduling phase. The configured action sequence is the scheduler execution sequence. For details, see Actions.
    The scheduler traverses all jobs to be scheduled and performs actions such as enqueue, allocate, preempt, and backfill in the configured sequence to find the most appropriate node for each job.
    The following options are supported:
    • enqueue: uses a series of filtering algorithms to filter out tasks to be scheduled and sends them to the queue to wait for scheduling. After this action, the task status changes from pending to inqueue.
    • allocate: selects the most suitable node based on a series of pre-selection and selection algorithms.
    • preempt: performs preemption scheduling for tasks with higher priorities in the same queue based on priority rules.
    • backfill: schedules tasks in the pending state as much as possible to maximize node resource utilization.
    Example:
    actions: 'allocate, backfill, preempt'
    When configuring actions, use either preempt or enqueue.
    default_scheduler_conf.tier.plugin
    Implementation details of algorithms in actions based on different scenarios. For details, see Plugins.
    For details, see Table 5.
    Descheduling
    descheduler_enable
    Used to enable descheduling.
    This function is disabled by default. Options:
    • true: The function is enabled.
    • false or empty: The function is disabled.
    deschedulerPolicy
    Descheduling policy
    For details about the parameters, see Table 2.
    Descheduling period
    Value range: > 0s; parameter type: time
    Cloud native hybrid deployment
    colocation_enable
    Used to enable cloud native hybrid deployment.
    Method for calculating the oversubscription
    nodeResource and podProfile are supported. The default value is nodeResource.
    • nodeResource: calculates the oversubscription based on the node resource usage.
    • podProfile: calculates the oversubscription based on pod profiling.
    Percentage of idle resource oversubscription of a node
    Value range: 1 to 100; parameter type: int
    For example, 60 indicates that the maximum oversubscription resources on a node is calculated based on 60% × Idle resources on the node.
    Period of pod profiling
    Value range: 60 to 2592000, in seconds, that is, from 1 minute to 1 month. If a pod's metrics are not collected for the entire period, the node's resources will be evaluated according to the resources requested by the pod.
    When the oversubscription algorithm based on pod profiling is enabled for the first time, the amount of collected data may not be sufficient to cover the entire period. In this case, the oversubscription on the node is temporarily 0 due to lack of initialization data. After the data of the first period is collected, the oversubscription is updated to the actual value.
    Table 5 Supported plugins
    Plugins
    Function
    Demonstration
    binpack
    Schedule pods to nodes with high resource usage (not allocating pods to light-loaded nodes) to reduce resource fragments.
    arguments:
    • binpack.weight: weight of the binpack plugin.
    • binpack.cpu: ratio of CPUs to all resources. The parameter value defaults to 1.
    • binpack.memory: ratio of memory resources to all resources. The parameter value defaults to 1.
    • binpack.resources: other custom resource types requested by the pod, for example, nvidia.com/gpu. Multiple types can be configured and be separated by commas (,).
    • binpack.resources.<your_resource>: weight of your custom resource in all resources. Multiple types of resources can be added. <your_resource> indicates the resource type defined in binpack.resources, for example, binpack.resources.nvidia.com/gpu.
    - plugins:
      - name: binpack
        arguments:
          binpack.weight: 10
          binpack.cpu: 1
          binpack.memory: 1
          binpack.resources: nvidia.com/gpu, example.com/foo
          binpack.resources.nvidia.com/gpu: 2
          binpack.resources.example.com/foo: 3
    conformance
    Prevent key pods, such as the pods in the kube-system namespace from being preempted.
    None
    - plugins:
      - name: 'priority'
      - name: 'gang'
      - name: 'conformance'
    lifecycle
    By collecting statistics on service scaling rules, pods with similar lifecycles are preferentially scheduled to the same node. With the horizontal scaling capability of the Autoscaler, resources can be quickly scaled in and released, reducing costs and improving resource utilization.
    1. Collects statistics on the lifecycle of pods in the service load and schedules pods with similar lifecycles to the same node.
    2. For a cluster configured with an automatic scaling policy, adjust the scale-in annotation of the node to preferentially scale in the node with low usage.
    arguments:
    • lifecycle.WindowSize: The value is an integer greater than or equal to 1 and defaults to 10.
      Record the number of times that the number of replicas changes. If the load changes regularly and periodically, decrease the value. If the load changes irregularly and the number of replicas changes frequently, increase the value. If the value is too large, the learning period is prolonged and too many events are recorded.
    • lifecycle.MaxGrade: The value is an integer greater than or equal to 3 and defaults to 3.
      It indicates levels of replicas. For example, if the value is set to 3, the replicas are classified into three levels. If the load changes regularly and periodically, decrease the value. If the load changes irregularly, increase the value. Setting an excessively small value may result in inaccurate lifecycle forecasts.
    • lifecycle.MaxScore: float64 floating point number. The value must be greater than or equal to 50.0. The default value is 200.0.
      Maximum score (equivalent to the weight) of the lifecycle plugin.
    • lifecycle.SaturatedTresh: float64 floating point number. If the value is less than 0.5, use 0.5. If the value is greater than 1, use 1. The default value is 0.8.
      Threshold for determining whether the node usage is too high. If the node usage exceeds the threshold, the scheduler preferentially schedules jobs to other nodes.
    - plugins:
      - name: priority
      - name: gang
      - name: conformance
      - name: lifecycle
        arguments:
          lifecycle.MaxGrade: 3
          lifecycle.MaxScore: 200.0
          lifecycle.SaturatedTresh: 0.8
          lifecycle.WindowSize: 10
    • For nodes that do not want to be scaled in, manually mark them as long-period nodes and add the annotation volcano.sh/long-lifecycle-node: true to them. For an unmarked node, the lifecycle plugin automatically marks the node based on the lifecycle of the load on the node.
    • The default value of MaxScore is 200.0, which is twice the weight of other plugins. When the lifecycle plugin does not have obvious effect or conflicts with other plugins, disable other plugins or increase the value of MaxScore.
    • After the scheduler is restarted, the lifecycle plugin needs to re-record the load change. The optimal scheduling effect can be achieved only after several periods of statistics are collected.
    Gang
    Consider a group of pods as a whole for resource allocation. This plugin checks whether the number of scheduled pods in a job meets the minimum requirements for running the job. If yes, all pods in the job will be scheduled. If no, the pods will not be scheduled.
    If a gang scheduling policy is used, if the remaining resources in the cluster are greater than or equal to half of the minimum number of resources for running a job but less than the minimum of resources for running the job, Autoscaler scale-outs will not be triggered.
    • enablePreemptable:
      • true: Preemption enabled
      • false: Preemption not enabled
    • enableJobStarving:
      • true: Resources are preempted based on the minAvailable setting of jobs.
      • false: Resources are preempted based on job replicas.
      • The default value of minAvailable for Kubernetes-native workloads (such as Deployments) is 1. It is a good practice to set enableJobStarving to false.
      • In AI and big data scenarios, you can specify the minAvailable value when creating a vcjob. It is a good practice to set enableJobStarving to true.
      • In Volcano versions earlier than v1.11.5, enableJobStarving is set to true by default. In Volcano versions later than v1.11.5, enableJobStarving is set to false by default.
    - plugins:
      - name: priority
      - name: gang
      - name: conformance
    priority
    Schedule based on custom load priorities.
    None
    - plugins:
      - name: priority
      - name: gang
      - name: conformance
    overcommit
    Resources in a cluster are scheduled after being accumulated in a certain multiple to improve the workload enqueuing efficiency. If all workloads are Deployments, remove this plugin or set the raising factor to 2.0.
    This plugin is supported in Volcano 1.6.5 and later versions.
    arguments:
    • overcommit-factor: inflation factor, which defaults to 1.2.
    - plugins:
      - name: overcommit
        arguments:
          overcommit-factor: 2.0
    drf
    The Dominant Resource Fairness (DRF) scheduling algorithm, which schedules jobs based on their dominant resource share. Jobs with a smaller resource share will be scheduled with a higher priority.
    None
    - plugins:
      - name: 'drf'
      - name: 'predicates'
      - name: 'nodeorder'
    predicates
    Determine whether a task is bound to a node by using a series of evaluation algorithms, such as node/pod affinity, taint tolerance, node repetition, volume limits, and volume zone matching.
    None
    - plugins:
      - name: 'drf'
      - name: 'nodeorder'
    nodeorder
    A common algorithm for selecting nodes. Nodes are scored in simulated resource allocation to find the most suitable node for the current job.
    Scoring parameters:
    • nodeaffinity.weight: Pods are scheduled based on node affinity. This parameter defaults to 2.
    • podaffinity.weight: Pods are scheduled based on pod affinity. This parameter defaults to 2.
    • leastrequested.weight: Pods are scheduled to the node with the least requested resources. This parameter defaults to 1.
    • balancedresource.weight: Pods are scheduled to the node with balanced resource allocation. This parameter defaults to 1.
    • mostrequested.weight: Pods are scheduled to the node with the most requested resources. This parameter defaults to 0.
    • tainttoleration.weight: Pods are scheduled to the node with a high taint tolerance. This parameter defaults to 3.
    • imagelocality.weight: Pods are scheduled to the node where the required images exist. This parameter defaults to 1.
    • podtopologyspread.weight: Pods are scheduled based on the pod topology. This parameter defaults to 2.
    - plugins:
      - name: nodeorder
        arguments:
          leastrequested.weight: 1
          mostrequested.weight: 0
          nodeaffinity.weight: 2
          podaffinity.weight: 2
          balancedresource.weight: 1
          tainttoleration.weight: 3
          imagelocality.weight: 1
          podtopologyspread.weight: 2
    GPU-topology scheduling preselection algorithm
    None
    - plugins:
      - name: 'cce-gpu-topology-predicate'
      - name: 'cce-gpu-topology-priority'
      - name: 'xgpu'
    GPU-topology scheduling priority algorithm
    None
    - plugins:
      - name: 'xgpu'
    cce-gpu
    GPU resource allocation that supports decimal GPU configurations by working with the CCE AI Suite (NVIDIA GPU) add-on.
    None
    - plugins:
      - name: 'cce-gpu'
    numa-aware
    NUMA affinity scheduling. For details, see NUMA Affinity Scheduling.
    arguments:
    • weight: weight of the numa-aware plugin
    - plugins:
      - name: 'nodelocalvolume'
      - name: 'nodeemptydirvolume'
      - name: 'nodeCSIscheduling'
      - name: 'networkresource'
        arguments:
          NetworkType: vpc-router
      - name: numa-aware
        arguments:
          weight: 10
    networkresource
    The ENI requirement node can be preselected and filtered. The parameters are transferred by CCE and do not need to be manually configured.
    arguments:
    • NetworkType: network type (eni or vpc-router)
    - plugins:
        arguments:
    nodelocalvolume
    Filter out nodes that do not meet local volume requirements.
    None
    - plugins:
    nodeemptydirvolume
    Filter out nodes that do not meet the emptyDir requirements.
    None
    - plugins:
    nodeCSIscheduling
    Filter out nodes with malfunctional Everest.
    None
    - plugins:
Components
Table 6 Add-on components
Component
Resource Type
volcano-scheduler
Schedule pods.
Deployment
volcano-controller
Synchronize CRDs.
Deployment
volcano-admission
Webhook server, which verifies and modifies resources such as pods and jobs
Deployment
volcano-agent
Cloud native hybrid agent, which is used for node QoS assurance, CPU burst, and dynamic resource oversubscription
DaemonSet
resource-exporter
Report the NUMA topology information of nodes.
DaemonSet
volcano-descheduler
Reschedule pods in a cluster. After the rescheduling capability is enabled, pods will be automatically deployed on nodes.
Deployment
Modifying the volcano-scheduler Configurations Using the Console
volcano-scheduler is the component responsible for pod scheduling. It consists of a series of actions and plugins. Actions should be executed in every step. Plugins provide the action algorithm details in different scenarios. volcano-scheduler is highly scalable. You can specify and implement actions and plugins based on your requirements.
After the add-on is installed, you can choose Settings in the navigation pane, switch to the Scheduling tab, and configure the basic scheduling capabilities. You can also use the expert mode of the Volcano scheduler to customize advanced scheduling policies based on service scenarios.
This section describes how to configure volcano-scheduler.
Only Volcano of v1.7.1 and later support this function.
Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Settings and click the Scheduling tab. In the Select Cluster Scheduler area, select Volcano scheduler, find the expert mode, and click Try Now.
  • Using resource_exporter:
        "default_scheduler_conf": {
            "actions": "allocate, backfill, preempt",
            "tiers": [
                    "plugins": [
                            "name": "priority"
                            "name": "gang"
                            "name": "conformance"
                    "plugins": [
                            "name": "drf"
                            "name": "predicates"
                            "name": "nodeorder"
                    "plugins": [
                            "name": "cce-gpu-topology-predicate"
                            "name": "cce-gpu-topology-priority"
                            "name": "cce-gpu"
                            "name": "numa-aware" # add this also enable resource_exporter
                    "plugins": [
                            "name": "nodelocalvolume"
                            "name": "nodeemptydirvolume"
                            "name": "nodeCSIscheduling"
                            "name": "networkresource"
    After this function is enabled, you can use the functions of both numa-aware and resource_exporter.
Collecting Prometheus Metrics
volcano-scheduler exposes Prometheus metrics through port 8080. You can build a Prometheus collector to identify and obtain volcano-scheduler scheduling metrics from http://{{volcano-schedulerPodIP}}:{{volcano-schedulerPodPort}}/metrics.
Prometheus metrics can be exposed only by the Volcano add-on of version 1.8.5 or later.
Table 7 Key metrics
Metric
Type
Label
e2e_scheduling_latency_milliseconds
Histogram
E2E scheduling latency (ms) (scheduling algorithm + binding)
None
e2e_job_scheduling_latency_milliseconds
Histogram
E2E job scheduling latency (ms)
None
e2e_job_scheduling_duration
Gauge
E2E job scheduling duration
labels=["job_name", "queue", "job_namespace"]
plugin_scheduling_latency_microseconds
Histogram
Add-on scheduling latency (µs)
labels=["plugin", "OnSession"]
action_scheduling_latency_microseconds
Histogram
Action scheduling latency (µs)
labels=["action"]
task_scheduling_latency_milliseconds
Histogram
Task scheduling latency (ms)
None
schedule_attempts_total
Counter
Number of pod scheduling attempts. unschedulable indicates that the pods cannot be scheduled, and error indicates that the internal scheduler is faulty.
labels=["result"]
pod_preemption_victims
Gauge
Number of selected preemption victims
None
total_preemption_attempts
Counter
Total number of preemption attempts in a cluster
None
unschedule_task_count
Gauge
Number of unschedulable tasks
labels=["job_id"]
unschedule_job_count
Gauge
Number of unschedulable jobs
None
job_retry_counts
Counter
Number of job retries
labels=["job_id"]
Uninstalling the Volcano Add-on
After the add-on is uninstalled, all custom Volcano resources (Table 8) will be deleted, including the created resources. Reinstalling the add-on will not inherit or restore the tasks before the uninstallation. It is a good practice to uninstall the Volcano add-on only when no custom Volcano resources are being used in the cluster.
Table 8 Custom Volcano resources
Item
API Group
API Version
Resource Level
Command
bus.volcano.sh
v1alpha1
Namespaced
Job
batch.volcano.sh
v1alpha1
Namespaced
Numatopology
nodeinfo.volcano.sh
v1alpha1
Cluster
PodGroup
scheduling.volcano.sh
v1beta1
Namespaced
Queue
v1beta1
Cluster
