Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        API Management/
        Importing and Exorting APIs/
        Extended Definition/
      x-apigateway-any-method
Meaning: API request method used by default if no HTTP request method is specified.
Scope of effect: Path Item Object (2.0)/Path Item Object (3.0)
Example:
paths:
  '/path':
    get:
      produces:
        - application/json
      responses:
        "200":
          description: "get response"
    x-apigateway-any-method:
      produces:
        - application/json
      responses:
        "200":
          description: "any response"
       Parameter  |
       Mandatory  |
       Type  |
       Description  |
       x-apigateway-any-method  |
       No  |
       String  |
       Request method.  |
   Parent topic: Extended Definition
